need help reviving a 2000 accord
Old Jun 3, 2015 | 07:42 PM
rimestime's Avatar
Default need help reviving a 2000 accord
this darn accord has been sitting in my driveway for a year now and i just started my attempt to get it running. The car cranks has power but doesnt turn over. Ive changed plugs, wires, dizzy cap/rotor, battery, all fluids, and timing belt. its a 2000 accord automatic. What should I do next?
Old Jun 4, 2015 | 09:14 AM
bw77's Avatar
Default Re: need help reviving a 2000 accord
Have you tried spraying carb cleaner in the air intake?
Have you checked for spark?
Have you checked for compression?
Old Jun 4, 2015 | 03:11 PM
rimestime's Avatar
there is spark and compression ran 190. 190. 200. 190
are these numbers acceptable? its a 4 cylinder . sprayed carb cleaner and still no luck.
Old Jun 5, 2015 | 03:01 AM
bw77's Avatar
Compression looks good.
Are you sure that the plug wires are connected in
the right order?
Could the timing be a tooth off?
When you sprayed carb cleaner while cranking
did you use enough to make the plugs wet?
Old Jun 5, 2015 | 02:47 PM
91Accordkid's Avatar
Id just check a few things. Since its getting spark check for fuel get someone to crank while spraying a little bit of carb cleaner or starting fluid. Id also recheck the timing marks and make sure they line up.
I would also highly recommend just getting a scan tool and hooking it up. Just to see if there are any codes.
Old Jun 6, 2015 | 05:13 AM
jollyhonda's Avatar
I would double check plug wires. Compression looks very good. Does it try to start at all?
Mor6an2613
Jan 29, 2017 07:43 AM
fitbkeco
10
Mar 2, 2013 02:15 AM
sivikvtec
Oct 20, 2009 05:59 AM
thatfastteg
Feb 21, 2007 07:55 PM
