ECU Chipping & O2 sensors
Old Nov 4, 2002 | 03:21 PM
Danbu$'s Avatar
Default ECU Chipping & O2 sensors
Hey guys need some help,
just dropped my b16 into my civic and im using a Jasma 4-2-1 header. I know if i want the b16 to run right i have to have the 2 o2 sensors properly hooked up I.E. welding 2 bungs into the primarys of the header to get correct 02 readings.
I have read that you can get your ecu chipped so that it only needs\see's one 02 sensor.
my question is if i have the ecu chipped so that is dosen't see that secondary 02 sensor and i dont have the fuel map or anything else changed, will it run right ?
what i want to do is just have the computer chipped and run 1 o2 sensor from where the original bung is on the header (near the collector)
Will this fix my problem ? or will it still run to rich\lean ?
BTW, i have done a good amount of reasearch on this, so anybody telling my to use the search button will kindly be asked to tongue my right nut.
thanks,
Dan
Old Nov 4, 2002 | 03:24 PM
Urban Business
Guest
Posts: n/a
Default Re: ECU Chipping & O2 sensors (Danbu$)
if you chip the ecu to nix the 2nd o2 SCAMMER the car will run fine. by not chipping and not having the 2nd o2 scammer or any it'll run rich as ****.
Old Nov 4, 2002 | 03:31 PM
Danbu$'s Avatar
Default Re: ECU Chipping & O2 sensors (TorteX)
For sure man ?
I just dont wanna chip it and have that not solve the problem
moneys kinda tight, dont wanna waste it
Old Nov 4, 2002 | 03:42 PM
bryant's Avatar
yeah, but chipping it, the ECU will no longer look for it. so you wont have to worry it being plugged in or connected
Old Nov 4, 2002 | 03:59 PM
Urban Business
Guest
Posts: n/a
Default Re: ECU Chipping & O2 sensors (CR-X)
yeppers
Old Nov 4, 2002 | 05:45 PM
dumbchild's Avatar
chip it
the Mugen program is one that will work...
Old Nov 4, 2002 | 05:46 PM
Danbu$'s Avatar
Default Re: ECU Chipping & O2 sensors (dumbchild)
Sweet
thanks guys
H-T is the **** !
OldSchoolFool
May 21, 2015 02:31 PM
soon2b
Feb 4, 2004 08:07 AM
shadowstylz
13
Sep 15, 2003 10:33 PM
