Stuck mode motor
Old Jun 2, 2015 | 02:27 PM
techfoo's Avatar
Default Stuck mode motor
I've read many posts on this site that talk about replacing the mode motor when your vent buttons don't change the air direction. So I replaced my mode motor and it works the same as the old one, which is to say it only works about 10% of the time.
Both motors act like the whole assembly is jammed or stuck. If I nudge the arms they will sometimes slowly move into place. But as I cycle through the buttons the assembly will stop moving again. Is there a fix for this? Maybe a bad resistor?
Old Jun 2, 2015 | 03:50 PM
holmesnmanny's Avatar
Default Re: Stuck mode motor
Sometimes the solder joints wear out.
Old Jun 2, 2015 | 04:41 PM
techfoo's Avatar
Where would I look for bad solder joints?
Old Jun 2, 2015 | 08:20 PM
You have to remove the instrument trim and then pull the climate control panel and resolder the joints in it. It's like resoldering a main relay.
Old Jun 6, 2015 | 03:03 AM
Lost Again's Avatar
What year Accord are you working on?
Old Jun 7, 2015 | 05:10 AM
techfoo's Avatar
This is a 98 Accord. I hope theres a way to grease up the mechanism to make it work.
Old Jun 7, 2015 | 08:57 AM
Lost Again's Avatar
If you haven't "lubed" the linkage, that would be a place to start.
Different gen but my 5th gen would do the same thing. I would then lube the linkage and be good for another few years.
"Usually" when the PCB on the 6th gen's manual HVAC goes bad the whole thing goes out.....no power at all......no AC, no blower, no lights....dead.
NOFX
Nov 30, 2023 02:23 PM
tmiani59
Jul 3, 2019 03:38 AM
jimi323
Aug 20, 2015 11:37 AM
MileHigh
May 28, 2009 06:49 AM
Chanchito
Jun 10, 2008 04:36 PM
