NY 1994 Acura Integra 4DR RHD JDM Front Spec R Motor JRSC LHT Project
I've been going back and forth on wether I want to sell or not. If the right offer comes in, I will let it go. Reason I'm selling- I honestly don't have time to finish the project right now. I have my lady, 2 kids, a house and (with the short NY summers) fishing season that require more than 100% of my time.
Make- Acura
Model- Integra LS 4dr
Yr- 1994
Mileage- Body: 120k Motor: 70k
Title- Clear
Price- $9,000 obo
Engine
- JDM '98 Spec Type R
- JRSC Supercharger
- LHT Intercooler Manifold w S-Tube Ported to 68mm
- LHT Header
- Spoon Sports Baffled Oil Pan
- Spoon Sports Valve Cover
- Spoon Sports Plug Kevlar
- Spoon Sports Oil Cap
- Spoon Sports Hose Kit
- Spoon Sports Plugs and Wires
- Spoon Sports Engine Torque Damper
- Spoon Sports N1
- Spoon Sports Shift Rod
- Spoon Sports Shift Bushings
- Spoon Sports Reservoir Covers
- Skunk2 Composite Fuel Rail
- Skunk2 Pro Series Cam Gears
- Skunk2 68mm Black Series Throttle Body
- Skunk2 Vtec Solenoid Cover
- Skunk2 Cam Seal
- AEM Fuel Pressure Regulator
- RC Engineering 750cc injectors
- Innovative Motor Mounts
- ChaseBays Fuel Line Tuck Kit w Inline Fuel Filter
- ChaseBays Brake Booster Delete Kit
- ChaseBays Brake Line Relocation Kit
- ChaseBays CM2 Engine Harness
- ChaseBays Overflow Tank
- All-In-Fab Tucked Radiator
Exterior
- Color: Championship White
- JDM Front End Conversion
- 15" Spoon Sports SW388 Wheels
- Project Kics R40 Lug Nuts
Suspension
- JDM ITR 5Lug Conversion
- AMR Full Coilovers
- Spoon Sports Twin Block Calipers
- Spoon Sports Rear Strut Bar
- StopTech Drilled Brake Kit
- Function7 Rear Lower Control Arms
- Skunk2 Pro Series Plus Front Camber Kit
- Skunk2 Rear Camber Kit
- ARP Extended Studs
- HOP Trailing Arm Bushings
- HOP Front Wheel Bearings
Interior
- Right Hand Drive Conversion
- Red Recaros
- Spoon Sports Steering Wheel
- Spoon Sports Blue Wide Rear View
- Spoon Sports Aluminum Shift ****
- Skunk2 Short Shifter
- Takata Harnesses
A lot of the parts listed were purchased new in 2014.
Things that need to be done.
- Install Transmission Cover, Shifter rod
- Finish taping up and running all the wiring through Fenders, grounds- (purchased an OEM Right hand drive chassis harness for it.)
- Install all the Engine Bay grounds
- Add fluids, Bleed brakes,etcetc
- Fix door lock mechanism and door stoppers
- Purchased a spoon n1 muffler for it. Was going to convert the piping 2.5in with custom 2.5in piping to the front. (so that's gotta be done. I was going to have Synapse do the work along with the tune once running.
If you have any questions or need more pictures, contact me.
PS- mods I'll be adding more pictures with my username soon. Thanks
Make- Acura
Yr- 1994
Title- Clear
Price- $9,000 obo
Engine
- JRSC Supercharger
- LHT Header
- Spoon Sports N1
- Skunk2 Cam Seal
Exterior
Suspension
Interior
- Red Recaros
- Takata Harnesses
I just flipped my 99 gsr twice going 140mph last weekend on the i95. im okay shes totaled
looking for a new teggy and saw this guy on ebay! its a dope car but I want the 2 door hands down. GLWS!
It's pretty doubtful that you should be looking for your next tight project, especially after 2 rolls at 140mph!! 😐😔😲
if you ever decide to part it out i have dibs on the lht manifold. i live in az and definately need one lol... but seriously i want it if you decide to part it out.
