2002 EX passenger window problem
Old Jun 1, 2015 | 04:35 AM
02EX's Avatar
Default 2002 EX passenger window problem
I changed both of my regulators and motors yesterday and now my passenger window won't move... I made sure everything is reconnected right, fuses look good, driver window works fine, I'm not sure what to check next? The window won't move using the switch on either door. I hooked the old motor back up and it doesn't move either.
I had the window rolled up and pulled into place for about a week since it started falling down. I'm not positive that it worked before I replaced the regulator and motor. Any help would be appreciated. I have the window taped up right now
Old Jun 1, 2015 | 04:25 PM
Lost Again's Avatar
Default Re: 2002 EX passenger window problem
Have a volt meter and some time....this could be anything from a bad switch (drivers and or pass side) to a multiplex issue......or as simple as the wires in the door jam have come loose/broken.
So, my opinion. start working backwards.....are you getting power to the motor....are you getting the right signal from the multiplex...is the multiplex getting the right input....ect.
slipstreamvash
Feb 1, 2015 05:26 AM
sjbmx
Aug 9, 2009 05:38 AM
92ehatch
Mar 3, 2006 02:49 AM
staticrex
Sep 19, 2005 11:30 AM
poison
Mar 29, 2003 02:47 PM
