Transmission & Drivetrain Gearboxes, Differentials, Clutches
B16b jdm civic type r transmission oil
Old May 31, 2015 | 05:26 AM
Bony123's Avatar
Default B16b jdm civic type r transmission oil
What should the transmission oil be for b16b type r civic.is mobil 75w90 or redline mtx 85 ok or any other oil.bit genuine honda mtf is not available in my country.need help pls
Old May 31, 2015 | 02:38 PM
DVDr's Avatar
Default Re: B16b jdm civic type r transmission oil
honda mtf is a good option or torco mtf ( either conventional of fully syn )
the mobil might be way to thick.
Old Jun 1, 2015 | 05:53 AM
Aquafina's Avatar
Do not use Honda MTF.
What country do you live in?
Old Jun 1, 2015 | 05:59 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Just curious, why not Honda MTF?
Old Jun 1, 2015 | 06:50 AM
DVDr's Avatar
many people say the new formula is too thin. while true. im sure it still provides more than sufficient additives to protect the gears.
Is it the best option, probably not. Torco that is focused more on performance might be a better option.
Old Jun 1, 2015 | 01:19 PM
holmesnmanny's Avatar
Nothing out there works better than Honda mtf.
Old Jun 1, 2015 | 05:08 PM
Runnerdown's Avatar
You are in a very small crowd with that opinion. Do you rebuild them on a regular basis?
Old Jun 1, 2015 | 05:38 PM
Not on a regular basis no, but I've done enough. I've used a bunch of differnt fluids and honda seems to provide the best shifts and quietest sounding trannies.
Old Jun 1, 2015 | 06:52 PM
94EG8's Avatar
Seagull Management
You haven't tried Torco have you?
Old Jun 2, 2015 | 08:30 AM
Aquafina's Avatar
Too thin, lacks good EP additives. 10w-30 is a better option.
I'm guessing it will be easier for the OP to get hold of Motul than Torco.
Old Jun 2, 2015 | 09:57 AM
Honestly no.
Old Jun 3, 2015 | 10:17 AM
Aquafina's Avatar
Try it, you'll never go back to Honda MTF.
I have both MTF and RTF in stock ready to ship.
Old Aug 3, 2015 | 03:33 AM
Bony123's Avatar
I live in Bangladesh.But ive managed some redline mtl.should it be ok ?
Old Aug 3, 2015 | 10:21 AM
Bony123's Avatar
Will 10w-30 engine oil be ok for using in type r gear box.we have caltex both mineral and synthetic gear oil here
Old Aug 3, 2015 | 11:25 AM
94EG8's Avatar
Seagull Management
I'd go with Redline over 10W30 but you can use either.
Old Aug 3, 2015 | 11:55 AM
Bony123's Avatar
Ok 😃
Old Sep 26, 2015 | 07:29 PM
BrakeExpert's Avatar
Please remember that Honda calls for 10W-30 oil to be used as a temp replacement for Honda MTF. Believe me, Honda MTF is good stuff. Do NOT use a 75W-90. I mean just look at the numbers for a moment. The viscosity is way off. I for one tried to use that GM Synchromesh stuff years ago to try and "cure" grinds. It does for a little because the viscosity is wrong, and in a few months, you'll need new internal bearings. Everyone who says "I tried X fluid and it was awesome", go ask them if they can report back in 2 years and see if the incorrect fluid thickness made anything worse.
Old Sep 28, 2015 | 06:14 AM
m4xwellmurd3r's Avatar
Just so you know, gear oil weights are rated dofferent than motor oil weights. Viscocity wise a 75w-90 gear oil has the viscocity of 10w-40 motor oil
The reason for the numbers discrepancy is because SAE wanted to make sure people wouldnt accudentally grab a 10w-40 gear oil and mistake it for engine oil.
Old Sep 30, 2015 | 05:03 PM
civic-steve-94's Avatar
Last thing I tried was Lucas 20w-50 high zinc racing oil in my em1 trans and had no issues...
FEAR6655
Jul 2, 2011 11:42 PM
raene
Nov 23, 2002 01:11 AM
Ek4 B16A2
Sep 3, 2002 09:09 AM
Regular Series
Mar 2, 2002 07:58 PM
virginia_dude
Feb 11, 2002 07:14 AM
