Throttle body/TPS problems
Old May 30, 2015 | 09:49 AM
mindless head's Avatar
Default Throttle body/TPS problems
I don't usually work on my car but short on money so I decided to replace the TPS myself. I put a self diagnostics on my problematic 2000 Civic Dx after reading a whole lot and asking around about it. Now, I have a bigger problem because I kinda was harsh on those screws that don't necessarily come off easily. I banged with a hammer and a flat head little too hard I think and I broke one screw's housing on the body and I broke the other screw so it's stuck inside. Now I can't keep the new sensor in it's place. Although I started the car and ran it for two minutes, it didn't die on me. But, I was afraid to get out on the road with it. Do you think it would be safe for me and the car to drive when the sensor is not in its place? Is there any way I can do this via a tie or something? Thanks in advance.
Old May 30, 2015 | 11:53 AM
Former User's Avatar
Default Re: Throttle body/TPS problems
Sounds to me like you need to buy a new TPS.
For the original bolts/screws, remove TB and use a Dremel to score a line across the top of each bolt. Use a flathead screwdriver to remove.
After you install the TB with new TPS in the car, voltage calibrate it to read 0.5V at closed throttle.
Old May 31, 2015 | 07:32 AM
I already got the new sensor. I used a zip tie for now but I don't think I can calibrate in that position until I figure out how to get the broken screw out.
Old May 31, 2015 | 09:01 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Originally Posted by mindless head
I think I broke one screw's housing on the body and I broke the other screw so it's stuck inside.
By this, do you mean you broke the tang on the TPS or you broke the aluminum threads on the throttle body?
If on the throttle body, you might be able to cheat with JB Weld cold weld. The problem with this is dependent on how the break is and how you fix it. If you have to glue the screw in place, I would change the screw to a stud and use a nut instead so you don't have to ever attempt getting the screw/stud out. Thus will also allow you to loosen and adjust at will.
On the broken screw... Is it broken flush to the throttle body? If it is, then it's a drill out and retap it situation. I've never had good success using easy outs on totally seized bolts/screws.
If however the screw broke high enough, you should be able to grab enough of the screw with vice grips and twist it out.
Old May 31, 2015 | 07:38 PM
4imports.net's Avatar
you need to test for voltage from the center wire. that is the signal wire for tps. should read .05 closed and around 4.5 wot
Evasion
Aug 20, 2010 05:37 PM
cazper8890
Mar 2, 2007 08:25 PM
seelyd
Feb 5, 2007 10:01 AM
gsr98teg
Feb 18, 2004 04:07 PM
SIcivic10
Sep 29, 2002 05:33 PM
