P0117 ECT circuit low
1997 Civic with a LS swap LS ECU and LS Harness. For some reason I'm getting this code I checked the wire that goes back to the ECU and its fine I get 5V from the ECU and I get 5V to the sensor. I checked the ground wire by putting one end of my DVOM to batter + and the other to the wire and I get good ground what am I missing? How do I know If the sensor is good?
Your right the color is Red with white strip 5V
3.0 ohm on the sensor and with a scan tool in getting a reading of 215 C on the ECT and 23on the IAT and about 1 Ohm resistance from the pig tail to the ECU for D11 (green wire)
DaCRXboi
Aug 20, 2005 10:40 PM
dingusjt
Nov 13, 2003 10:18 AM
