Car is leaking oil..
Old May 29, 2015 | 02:55 PM
ls1formula98's Avatar
Default Car is leaking oil..
1994 Accord. The leak was not a major issue when I bought the car (maybe a couple of drops in a couple of days) , however It has slowly progressed and is now 2 to 3 drops a day. I looked underneath the vehicle and I don't think its coming from the pan itself. I could be wrong. My question is this is a problem with these cars, if so where does the leak come from? Thanks.
Old May 29, 2015 | 04:59 PM
jollyhonda's Avatar
Default Re: Car is leaking oil..
The distributor o-ring is a very common leak on pretty much all overhead cam motors. What creates a more serious issue is if it leaks long enough it will degrade the heater hose beneath it until it softens up enough to blow out.
Old May 29, 2015 | 10:33 PM
PerformanceFirst's Avatar
The oil pressure switch is a common point to leak. It's next to the oil filter. There are 3 seals behind the timing belt cover (crank, cam, balancer shaft) as well. If the leak is originating on the driver's side you might look there. I had a leak at the distributor... the heater hose blew a few years after fixing the leak. I'd also eliminate the valve cover gasket since that's easy to do. Pay attention to where the cover has cutouts for the camshaft.
Old May 30, 2015 | 02:32 AM
Jollyhonda/performancefirst come to think about it, I did have to change out my heater hose a couple of months back. However, I was having overheating issues at the time so I guess I got sidetracked for the moment. I will have a look at that this morning. Thanks.
Old May 30, 2015 | 08:33 AM
So I got under the hood an snapped a few pics. I looked and low and behold the hose is starting to get covered again. Sorry for all the weird angles. Sorry forgot to mention that I actually asked a question in the first pic.
Old May 30, 2015 | 06:13 PM
Yeah, the o-ring is on the distributor shaft where it enters the head. There's another seal inside the distributor too. If oil is getting inside it, that's your problem. There is a writeup in the FAQ on how to tackle that one.
hardrock2401
15
Jun 18, 2023 04:53 PM
coryfenton
Jun 4, 2009 04:48 PM
captainkickass
Mar 27, 2009 07:10 PM
SIRef9[831]
Nov 4, 2004 10:01 PM
Neukin
Mar 9, 2003 02:59 PM
