Can I run pump gas on toda B's?
Old Nov 4, 2002 | 02:44 PM
Nebula's Avatar
New User
Default Can I run pump gas on toda B's?
I'm planning on getting toda b's for my head. I want to know if I can run regular gas 93 or 94? My compression is going to be 11.1.
Old Nov 4, 2002 | 02:47 PM
Big Phat R's Avatar
Default Re: Can I run pump gas on toda B's? (Nebula)
no problem
Old Nov 4, 2002 | 02:49 PM
92TypeR's Avatar
FSAE
Yes. With 92 you would be 'pushing it' with 12.1-12.5 compression. Do you plan on running with stock ignition timing also? WIth: 18 degree + 12.1 + toda B's = 92-93 octane from what I've seen. If you keep 11.1 you will be just fine.
[Modified by 92TypeR, 3:50 PM 11/4/2002]
Old Nov 4, 2002 | 02:51 PM
Austin's Avatar
Default Re: Can I run pump gas on toda B's? (92TypeR)
I had no issues on stock 10.6:1 with B's on 91 octane...and I tuned the car with a PowerFC.
Austin
Old Nov 4, 2002 | 03:07 PM
Black R's Avatar
25 Year Member
.....yes.
-it's the FIZZLE, y0!
Old Nov 4, 2002 | 03:09 PM
Nebula's Avatar
New User
Default Re: Can I run pump gas on toda B's? (Austin)
I knew I came to the right forum to ask this question. I will probably be using msd. Hoping to get low 13's with this setup on 11.1 and be daily driven. Thanks guys!
Old Nov 4, 2002 | 03:34 PM
Austin's Avatar
No need for the MSD.
Old Nov 4, 2002 | 03:37 PM
Eric R's Avatar
yeah, no needz for da MSD dizzle, y0!
Old Nov 4, 2002 | 03:44 PM
Eric R's Avatar
Note that the fuel octane you use got nothing to do with the cams you choose and vice-verza. It's only when you mess with compression when it counts.
I think if a car is legally streetable, it can run on pump gas anytime.
Old Nov 4, 2002 | 03:59 PM
mafay2's Avatar
New User
Default Re: Can I run pump gas on toda B's? (Tweety R)
With 94 octane and Toda B, you could probably run 12:1 CR if it is tuned right!!
Old Nov 4, 2002 | 04:00 PM
Austin's Avatar
Default Re: Can I run pump gas on toda B's? (mafay2)
You can run 91 with 13:1 <u>if</u> it's tuned correctly.
Old Nov 4, 2002 | 04:02 PM
mafay2's Avatar
New User
True, but with 94 octane, it would give greater margin for error I guess.
Old Nov 4, 2002 | 08:59 PM
92TypeR's Avatar
FSAE
Agreed. I wouldn't want to risk my baby's life by puttin chitty gas in it.
Old Nov 4, 2002 | 09:26 PM
JUNGSR1's Avatar
yeah i have JUN stage 3 cams whitch i been told are bigger than the TODA SPEC b CAMS AND I HAVE NO PROBLEM YET . As long as you dont go over 12.9 comprssion you can still run on pumped gas . make sure you get the springs and the retainers ,and the rest of the goodies . and if your planning to run the toda ecu make sure you get some bottom end work done too cuz 9500rpm is alot for a honda motor to handle i made that mistake allready , get a clutch ,fly wheel ,and some injectors trust me it helps a lot
Old Nov 5, 2002 | 02:25 AM
00MRSi's Avatar
Default Re: Can I run pump gas on toda B's? (JUNGSR1)
As mentioned you can definitely run that setup without a problem.
Sunoco ULTRA 94 OWNZ..
lukeb89ef
17
Aug 25, 2011 10:37 PM
Toda Built
35
Sep 2, 2005 01:45 PM
EGkid
Sep 28, 2004 07:24 PM
Slow_Em1
May 28, 2004 10:13 AM
gary201147
Jan 23, 2003 11:49 AM
