Civic SI 2002 VTEC Mulfunctioning P1259
Old May 28, 2015 | 04:55 PM
Philip54's Avatar
Default Civic SI 2002 VTEC Mulfunctioning P1259
On my car every now and then the engine light goes on (Error P1259 VTEC Malfunctioning) and the engine does not go above 4,000 RPM. The problem goes away by itself after 50-100 miles.
I keep the oil level close to the maximum, so that is not the cause of the problem. The VTEC has been already changed 3 times. Recently a corroded pin was found on the VTEC connector. The pin was cleaned. Also both screens were removed, cleaned and re-installed, but I got another P1259 two days later. The problem seems to happen more frequently when I drive in heavy rain.
Any suggestions on what could be the cause of the VTEC malfunctioning?
Thanks
Old Aug 25, 2018 | 04:38 PM
bradferddd's Avatar
Default Re: Civic SI 2002 VTEC Mulfunctioning P1259
Did u wver find out the issue. Im having this problem
good on oil.
Vigoras
Mar 12, 2009 11:54 AM
Pleiadi79
Jun 12, 2008 08:22 AM
Fastwhip
Aug 2, 2007 03:58 PM
Rishiras
Oct 7, 2006 04:36 AM
SpeedGyrl
Mar 16, 2003 04:23 PM
