Thrust Bearing Question
Old May 28, 2015 | 09:53 AM
AdamMRTwo's Avatar
Default Thrust Bearing Question
So this may be a bit of a dumb question but I want to be sure. I am on a serious serious time crunch with my motor being rebuilt (less than 24hrs deadline) and have a set of clevite HX mains on the way. (ACL hxs are on national backorder) and ACL std were too tight) I already have ACL rods clearanced in spec and a set of new ACL thrust bearings. Can you mix and match the thrust bearings to the Mains? (B18C1 w eagle rods stock crank)
Old May 28, 2015 | 10:25 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Thrust Bearing Question
They do completely different things in different locations; Yes, you can run whatever set of thrust bearings that suits your fancy.
Old May 28, 2015 | 12:47 PM
AdamMRTwo's Avatar
Good to know, thanks!
JDM_ego2033
Engine Machining & Assembly
May 7, 2018 09:43 PM
JDM 98 GSR
K Series
Oct 27, 2011 11:09 PM
nkymain
11
Sep 22, 2005 01:25 PM
ppfalcon
Jun 21, 2005 09:38 PM
