B16A overheating
Old May 27, 2015 | 02:07 AM
GURLLUVSBASS's Avatar
Default B16A overheating
Hey guys
So I have a 90 crx with a jap spec b16a motor which intermittently overheats. I have come to the conclusion that it only happens when I hit vtec and/or just gun it while driving. If I take it easy and do not hit vtec it does not overheat. I have replaced thermo, flushed Collingwood system and bled, changed fan to see constant power while car is on. Only thing not replaced is rad and water pump. Heat gets hot and both rad hoses are warmish. Any ideas would be great. Any question just ask.
Thanks
Old May 27, 2015 | 07:19 AM
v4lu3s's Avatar
RTFM
Default Re: B16A overheating
Headgaskest imo, only overheats with high cylinder pressure. Saw the same thing with a gsr swap in my wife's car
Old May 27, 2015 | 04:42 PM
holmesnmanny's Avatar
A compression test will tell ya if the head gasket is leaking.
Old May 27, 2015 | 09:02 PM
v4lu3s's Avatar
RTFM
Not always. A compression test cannot simulate the actual pressure of combustion which is far more than the pumping pressure of the engine. I the engine I mentioned it had excellent leakdown and compression. New gasket, surfaced head and new fasteners and it never overheats. The other symptom w saw was a wandering temp needle as well.
Old Jun 1, 2015 | 04:17 AM
I did a compression test and it was fine. No milky oil neither. I was told by someone that I could be something to do with the impeller on the water pump? High rpms it will slip off or something.
G1tegra
Dec 23, 2018 03:15 AM
codywinnie
13
Apr 19, 2011 08:05 AM
joesss
Sep 4, 2007 05:00 AM
310BHPB16
Nov 25, 2004 02:19 PM
All Motor EG
Jul 30, 2002 10:35 PM
