Need help fixing cruise control
Iv checked the fuses the vaccum lines the pedal switches one thing I noticed is the cruise control button on the dash doesn't light up but the back light does any thing else I should check
Well, if cruise is not working, which could be entirely independent of if the switch light comes on or not, get a Helms service manual and start following the flow-chart to test items in the system.
My first guess would be dead bulb, second would be bad solders in the switch or a relay.
My Lude has not had cruise for the last 8-9 years now, so that is about all the help I can give.
So after taking about the steering colum I found the problem the connector the connects from the cable reel to the harness wasn't connected idk y but thank god it was only that t
Destin1
Feb 3, 2012 11:41 AM
rob42386
11
Feb 28, 2005 05:28 PM
