98 Civic DX Coupe - Ignition wires fried. Civic won't start.
Old May 24, 2015 | 10:26 AM
mesrop1991's Avatar
Default 98 Civic DX Coupe - Ignition wires fried. Civic won't start.
My family purchased a 199x civic coupe (no a/c) a couple years ago and haven't been using it. I went to crank it up and it wouldn't catch. These wires seemed to have been fried, which explains why the car wouldn't start! (Wires right above the ignition coil) anyone have any ideas why?
Old May 24, 2015 | 10:40 AM
White_EG1's Avatar
Default re: 98 Civic DX Coupe - Ignition wires fried. Civic won't start.
Whoa. Is this is a no crank no start or crank but won't start?
Old May 24, 2015 | 10:42 AM
W95civicEXcoupe's Avatar
GDD's Resident Derp
Hi there. Welcome.
Ok.. You don't know what year it is? No problem, we can help you determine that, but can you post a pic?
Also.. "won't start".. It has gas and compression? Forgive me if you said so, but, has it ever run before? I know you suspect No Spark. So you have Crank No Start. Yes?
Old May 24, 2015 | 02:13 PM
Former User's Avatar
Originally Posted by mesrop1991
199x civic coupe
How 'bout an actual year?
Old May 24, 2015 | 02:43 PM
chrysler kid's Avatar
I can't tell based on the up close picture but it looks like an oxygen sensor plug
You probably have a few blown fuses as well.
Your best bet is to re piN the plug
Old May 24, 2015 | 04:33 PM
tony_2018's Avatar
Fish Twig
Damn, seriously?
OP thats your distributor plug. It looks like it got chewed up really. You can go to the junkyard and cut one that you need or buy an entire engine harness just to be on the safe side, god knows what else is chewed up.
Old May 24, 2015 | 06:22 PM
94EG8's Avatar
Seagull Management
That's the distributor side of the distributor plug on a '96 - '98 Civic. Replace the distributor and see what happens. I don't think the wiring got fried, it looks like it was chewed by mice, rats, or squirrels.
Old May 25, 2015 | 08:39 AM
mesrop1991's Avatar
1998 Civic DX Coupe. Sorry - I have a lot to learn about posting on forums.
Cranks, but no "catch." Seemingly because the wired are fudged. It ran 3 years ago when it was purchased. Plenty of time for squirrels or mice to chew the wires up. Looks like they chewed up the o2 sensor wire as well! ��
Old May 25, 2015 | 08:43 AM
mesrop1991's Avatar
Old May 25, 2015 | 09:16 AM
tony_2018's Avatar
Fish Twig
Default Re: 98 Civic DX Coupe - Ignition wires fried. Civic won't start.
Wow........rats got to it really good. I fear for the rest of the unseen harness.
Old May 25, 2015 | 03:57 PM
mesrop1991's Avatar
Ok, I borrowed the distributer unit from my personal car. Same engine. Started up fine!
Two problems though: 1) the engine seems to be revving itself! It's a low rev. But definitely revving. I don't think it's connected to the harness issue. I'll post a video soon.
2) the radiator fan won't come on! Is there a fuse I should check? Or a wire location to look for more chewing?
Old May 25, 2015 | 03:59 PM
Do you the idle speed is surging up and down or the idle speed is too low?
Check for CEL codes.
You should also look for a mouse nest in the air intake system.
Old May 25, 2015 | 04:00 PM
mesrop1991's Avatar
Old May 25, 2015 | 04:05 PM
That's a surging idle.
Also check for a disconnected vacuum hose.
Old May 25, 2015 | 05:49 PM
redm3turbo's Avatar
could be air in the cooling system- check the fuses under hood/under dash, if they look good bleed the coolant system.
Old May 25, 2015 | 07:28 PM
b18c1 from hell's Avatar
Icon4 Re: 98 Civic DX Coupe - Ignition wires fried. Civic won't start.
if it was siting around it could be rats chewing on them that's what happened to my old civic
Old May 27, 2015 | 06:07 AM
Originally Posted by tony_2018
Damn, seriously?
It's hard to see on my cell phone
christopher.rie
11
Mar 23, 2015 04:09 AM
MarcoVzz
12
Jan 9, 2014 01:18 PM
sykotic
Sep 27, 2004 06:15 PM
