Tucked turbo coolant lines.... overheating?
Old May 23, 2015 | 07:00 PM
thermal's Avatar
Default Tucked turbo coolant lines.... overheating?
I've been researching for months... day and night. Recently, I've done a full shaved/tucked on my bay. Of course, I also tucked my coolant lines using 6AN fittings. So, the configuration now is: radiator bottom ---> turbo ---> block. I cant think of anything else why my motor would overheat after about 30 minutes of normal driving. I've done all the basics except remove the thermostat. So far, I've replaced the thermostat, temp sending unit, burped the system and checked fan rotation. the only other thing that I've done during my tucked process was go from a 14 inch pusher fan to 12 inch pusher fan but with higher CFM. It could also be my HG but the expansion tank have never overflowed and oil is not milky.
I'm thinking that maybe the flow of coolant is inefficient having to go straight from the turbo then to the block.
Please chime in. Your time is greatly appreciated.
Old May 23, 2015 | 07:11 PM
TheShodan's Avatar
Moderator
Default Re: Tucked turbo coolant lines.... overheating?
no. Its not the coolant going from turbo to the block. that is a very common configuration with today's block adapter/freeze plug fitting setups. It sounds to me that the pusher fan that you're using despite the higher CFM is not sufficient enough. You may also want to check intercooler/ radiator clearance.
But turbo coolant lines don't effect the block like that. The coolant isn't being super heated from the turbocharger to that degree to cause overeating conditions.
Old May 23, 2015 | 07:22 PM
thermal's Avatar
thanks Shodan. My radiator/intercooler clearance was the same as before I did the tuck so I dont think that's the issue. However, the fan could be the culprit so I will switch back to my 14 inch and see if the same issue arise. Thanks again!
Old May 23, 2015 | 10:43 PM
KevinEF7's Avatar
If its overheating while the car is moving a decent speed constantly, its not the fan.
Old May 24, 2015 | 04:41 AM
thermal's Avatar
Also, the water pump is brand new OEM.
Old May 24, 2015 | 05:36 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Just for clarification, when you say coolant lines and how you have things routed (radiator, turbo, block) you are NOT talking about your radiator hoses correct? Also, have you checked your radiator hoses for kinks? How did you bleed the system of air?
Old May 24, 2015 | 12:47 PM
thermal's Avatar
definitely not rad hoses. I was talking specifically about turbo coolant lines. My rad hoses are OEM routed, no weird routing, no tuck radiator, no kinks, no AN modified rad hoses. I bled the system using a no-drip funnel. Ran the motor like that for a while and allowed the fan to cycle on its own to make sure that the thermostat triggers it.
I'm gonna look into the fan. I do have just an eBay bought 12 inch fan. Looking at FAL or at least a Flex-a-lite... I have to remain on pusher set-up tho since I cant really fit anything for a puller.
Old May 24, 2015 | 03:10 PM
TheShodan's Avatar
Moderator
SPAL or Zirgo only.. You keep buying lower quality parts, it'll just get worse
GT500FTW
Apr 21, 2014 05:44 AM
InTheZoneAC
Feb 12, 2013 06:29 PM
96Integ
Mar 29, 2009 06:11 PM
Mr.Death
Jul 17, 2008 04:38 PM
