need help please idle problem
Old May 23, 2015 | 05:17 PM
MikeD21's Avatar
Default need help please idle problem
So my car is always idling at 1000 rpm and when I drive it far distances it'll start to idle around 1200 rpm. I've tried fixing it by adjusting the idle screw with the iacv unplugged and everything. Also I can't find a vaccum leak anywhere. I just need some help on trying to figure this out. Thank you
Old May 24, 2015 | 09:16 AM
sepheroth's Avatar
Default Re: need help please idle problem
Could be a dashpot.
Old May 24, 2015 | 11:05 AM
MikeD21's Avatar
What is a dashpot? Lol
Old May 24, 2015 | 11:18 AM
MikeD21's Avatar
Also I forgot to say that I did a Mpfi swap with a b7 intake manifold.
Old May 26, 2015 | 04:29 PM
MikeD21's Avatar
Bump
Old May 26, 2015 | 04:50 PM
MikeD21's Avatar
Bump
Old May 28, 2015 | 04:32 PM
cheap2's Avatar
My hatch idles high as well, even up to 3000rpm, found out the gas pedal sticks a lil bit, so I created the habit of lifting the pedal up from the back, works for me, but is not properly fixed.
Old May 28, 2015 | 07:20 PM
CrxChicken's Avatar
I would seriously just replace all your vacuum lines
I just did this.. lines looked old but still good... passed the carb cleaner test
Check the line to the Fuel Pressure Regulator.
If the regulator doesn't get enough sucking the RPM goes higher.
Could be a regulator...
But hit advance auto and pepboys replace every vacuum line you can .. will probably cost you $20 and probably something you should do anyway...
then .. test the fuel pressure regulator
you will need a fule pressure tester .. you hook it to your fuel filter at the service bolt
harbor freight has a $19 fuel pressure tester well it was $19 last week when i got one.
weaslehunter1
Jan 26, 2015 03:49 PM
boostedb20ek
Dec 11, 2009 12:52 PM
MugenFlaredCRX
Dec 11, 2006 07:40 PM
Jeff_B
Feb 7, 2005 06:51 PM
Dr. Gonzo
Jan 12, 2004 03:53 PM
