Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
A/C woes
Old May 23, 2015 | 02:09 PM
hall97civic's Avatar
Default A/C woes
Ok, 2004 honda accord ex with 2.4 and auto tranny.
AC won't work unless high pressure switch is bypassed.
temp outside was about 75°f
Low pressure - 30 psi
High pressure - around 180 psi
Shut it down and immediately low pressure rises. I walked away for 10 min to tackle something else and low/high pressure equaled out when I returned (approx 80psi).
When switch bypassed and car idling vent temp is 22°F. When running around 1500, vent temp is around 15°F and even with high pressure switch bypassed, the condensor fan and pump kick out for about 5 seconds all while maintaining approx 15-22°F vent temp.
Attempted to reach through bumper to test switch, set meter on 20k ohms and reading was around 0.190 if memory serves me correctly.
I'm stumped, what do you guys n gals think my next step should be?
sorry for thr lengthy post but wanted to include everything so far. Thanks in advance!
Old May 24, 2015 | 08:44 AM
Lost Again's Avatar
Default Re: A/C woes
Are you checking for continuity or resistance on the pressure switch?
You need continuity, if not there. Either low pressure in system or switch is bad.
Old May 24, 2015 | 12:54 PM
Checked resistance, I just checks for continuity and did not pass. Guess I'll order a pressurr switch then. Damn, I'll have to buy more refrigerant now. Dumb question, will I need to add any oil when recharging?
Freedo_Civegra
15
Jun 1, 2018 09:10 AM
tech61
Honda CR-V & Element
Aug 27, 2016 07:25 AM
cueto
22
Aug 4, 2011 07:02 PM
powerflow
Aug 28, 2009 11:16 AM
