2000 accord driver side cv axle wont go back in
Old May 23, 2015 | 10:45 AM
tomatolord's Avatar
Default 2000 accord driver side cv axle wont go back in
is there a trick ?
i have tried prying it in
i have tried hitting in back in while on the ball joint
and
Off of the ball joint.
it is about 1/2 shy of going in all the way.
I am afraid of hitting on the bearing as that seems to be aluminum and will probably crack off.
Any tips??
Old May 23, 2015 | 12:43 PM
holmesnmanny's Avatar
Default Re: 2000 accord driver side cv axle wont go back in
I like to sit on the ground and push the end in with my foot to pop it in but make sure the circlip is still on the end of the axle and its not bent or anything.
Just start with the axle a few inches out and to give it some time to pick up speed and it should pop in.
Old May 24, 2015 | 07:23 AM
N0mad54's Avatar
Did my 1999 DX last year but had the car on a lift up in the air. We had the air dam off so I believe we took it out from the bottom and installed reverse. In your case just apply some light force and wiggle the heck out of it and it should go in.
Old May 24, 2015 | 01:50 PM
MAD_MIKE's Avatar
MM Gruppe B
^This.
Gotta slide hammer it in useing the mass of the axle assembly.
Verify where the axle circlip is located. You will want the open ends in the 12 O'clock position so they are in the circlip groove. If the ends are left in the 6 O'clock position they are independent and can wedge and jam, preventing the axle from fully seating.
Old May 24, 2015 | 01:54 PM
Yeah, if I had to guess I would say the circlip got damaged and is what's preventing the axle from going in.
Old Jun 11, 2015 | 07:39 AM
tomatolord's Avatar
clip was ok..
i had to take axle out of hub, straighten, and hit hard with small sledge hammer and it popped right in. there were videos of people doing this.
Corksil
Nov 23, 2009 01:30 PM
iNERtIA
Jul 21, 2007 01:18 PM
Rooftop voter
Suspension & Brakes
Apr 9, 2007 08:38 AM
SkyLinER
Jul 6, 2004 07:04 AM
Cosworth
Jul 31, 2003 01:53 PM
