Bouncy Idle and overheating.
Old May 23, 2015 | 01:47 AM
VDK's Avatar
VDK
Default Bouncy Idle and overheating.
I went through the bouncy idle/overheating issues troubleshooting info and I did not see the answer to this problem.
I removed the thermostat and filled the radiator. I took the bleeder valve off and no liquid is coming out, only steam. It over heats and the idle is bouncy after the engine warms to operating temperature.
I verified with a block tester that I do not have a blown head gasket. The oil is not milky and I can not tell if bubbles are coming out of the radiator because there is a constant flow out of the radiator fill hole when it is at operating temperature.
I was thinking it may be a possible water pump issue or blockage somewhere.
I am not a mechanic. I am only going off of the troubleshooting guide on this site and your advice.
r.madrid75
Jan 11, 2016 05:04 PM
Skyhigh07
Jan 15, 2009 11:48 AM
variable
Aug 18, 2006 05:03 PM
loosestring
Nov 13, 2005 09:53 AM
Ri5e
Mar 30, 2002 03:57 PM
