97 civic problem shifting into 1st
Hey guys and gals
So I got a 97 civic coupe so this recently started happening . It's hard to put it in 1st gear like I would have to jam it in there for it to go in and sometimes same with 2nd also.. reverse will grind at times but all this will only happen when i drive it for a lil while and when car gets hot, Like when car is cold it will shift smother and its alot easier to put in 1st gear and reverse will not grind. What could this be ? My clutch slave cylinder ? 1/2 sleeve ? Btw i put in a fairly new clutch in about 2 weeks ago or less
You did a job that necessitates draining at least a little bit of fluid, and you didn't put any fluid back in? Do you understand how car lubricants work?
Ummm...how is this possible given that you must remove the axles from the differential to drop the transmission? If no MTF leaked out, then your transmission might not have any MTF in it.
Didnt drain ****
The drain pan was there but didnt drain anything on to it i really didnt need to
With the position the transmission is in that pic and there is no fluid leaking out... You probably barely have any fluid in it. Or any at all.
HondaDude83
Mar 4, 2011 11:42 AM
fred92htch
Aug 23, 2004 01:54 PM
