Bee R Rev Limiter Help Please?
Hi All,
I have installed a Bee R rev limiter into my JDM DC1 D16ZC SOHC non vtec, it came out of a d15 ek so I know its the correct version for a Honda.
It has a P76 Two plug ECU (apparantly a rare setup)
I have spliced in between Pin A21 on the ECU
The idea is to cut the ignition control module at points set on the Bee R limiter. (yes to make make pops and flames just for fun here and there).
My problem is, the Bee R works, it will cut ignition at whatever rev range I set, however if I press the throttle pedal more than halfway, the car cuts out and throws a management light until I turn off the car and start it again.
I have read endless threads and posts about the Bee R rev limiter, I understand how it works and how it should be installed into most Honda's, but I cannot figure why on my specific car it causes the engine the cut out/off when I press the throttle all the way down?
I also cannot find much info about my distributor, it has one black plug, plugged directly into the distributor with horizontal pins all in a line which has the yellow/green wire going into it from the ECU.
What is so different on my setup causing the engine to cut out?
Any help will be appreciated
Thank You.
Thank You.
dseriessol
Aug 18, 2003 09:22 AM
