Honda/Acura B series transmission parts! LSD, 4.4fd, synchros, etc
Old May 19, 2015 | 10:08 AM
Da1WiTsKiLz's Avatar
Default Honda/Acura B series transmission parts! Shafts, Gears, Synchros etc
Up for sale are my leftover transmission parts. Everything came out my own transmission or were leftover from my build. You will not have any issues with these parts. I will let everything go together for a significant discount. Keep in mind these prices include shipping and these parts are not light!
Synchrotech 1-5+R brass synchro + spring kit- Used for 40 miles in a freshly rebuilt transmission. You can see from the pictures that these synchros are all still close to new. This kit goes for $200 new. (only 2 pictured but all included) $120 shipped
S80 GSR Mainshaft- This is a GSR mainshaft in great shape. It can be used in a GSR or LS transmission $60 shipped
LS Countershaft + 4.26fd Ring Gear- This is an LS final drive set in great shape.This setup can drop right into a B16 or GSR transmission to give you a 4.26 final drive which would make for a transmission that is between a GSR and a B16 trans in terms of gearing. Great for higher 375+hp cars. 80 shipped
LS 1-4 gear sets (both main and countershaft)- These gears were all in good shape. I can confirm I did not have any shifting issues with them. The dog teeth all have normal wear, but nothing excessive. $80 shipped
1-2 slider and hub- As you can see from the pictures, this slider and hub are in great shape. No abnormal wear.
3-4 slider and hub- This hub shows wear but I drove the car with this transmission and it had no shifting issues between 3-4, even at redline. It also had no issues downshifting.
5-R slider and hub- As you can see from the pictures, this slider and hub are in great shape. No abnormal wear.
$75 shipped for all 3 slider/hubs and all 3 shift forks
Shift change holder assembly + shift rod with detent bolt, spring, ball bearing- Shift change holder in great shape, no noticable wear and no bends on the fingers. The shift rod is in great shape, it comes with the piece that contacts the shift change holder arm and all hardware. $55 shipped
Everything is located in Queens, NY. I am happy to put a package together for anyone.
Old May 20, 2015 | 11:16 AM
Default Re: Honda/Acura B series transmission parts! LSD, 4.4fd, synchros, etc
Added pictures
Old May 27, 2015 | 10:20 AM
Still available.
Old May 28, 2015 | 09:42 AM
Transmission case sold.
Old Jun 8, 2015 | 08:32 AM
GSR mainshaft, GSR countershaft, reverse idler set, LSD and ring gear sold!
Old Jun 12, 2015 | 11:31 AM
Just got my hands on 4.26 fd mainshaft and countershaft along with an LS 5th gear set. I am willing to part out the LS 5th for a fair offer.
If anyone is looking for a complete gear set I am willing to put together an entire LS gear set with these parts using the new synchros and springs above, a good set of hubs, sleeves, and bearings throughout. I will throw in the shift forks and change holder as well. Basically, if you are willing to help me clear my work bench I will give you a great deal for everything . I would take $325 shipped for that setup, which will be everything you need to update your blown LS transmission.
Old Jun 21, 2015 | 01:31 PM
Bump!
Old Jun 25, 2015 | 11:38 AM
Bump!
Old Jun 25, 2015 | 11:40 AM
Priced updated!
Old Aug 11, 2015 | 06:18 AM
Bump! Updated original post.
Old Sep 23, 2015 | 07:10 AM
Bump!
Old Oct 2, 2015 | 03:20 AM
Chris.'s Avatar
Honda-Tech Order of Merit
Please see here: Honda-Tech - Announcements in Forum : Regional Classifieds
Da1WiTsKiLz
Apr 21, 2016 02:35 PM
98GSR-Turbo
Apr 15, 2013 10:08 AM
crave13k
Oct 18, 2007 01:10 PM
