Gsr b20v swap wont rev past 4500
Hey guys . I've been doing some reading and I can't seem to figure out why my gsr won't pass 4500 on any gear . It's like it's limited . I've read that it could have been a dizzy but my dizzy is brand new . I have a p72 ecu I read that it could have been a possibility so I tried my buddies p72 off of his b20 swap. My car still wouldn't rev passed 4500. I do have a check engine light on and I did my own diag . It's obd1 and the only code it's giving me is 21 which is the vtec solenoid. I replaced the solenoid and oil pressure switch already. I still have the same problem. If I haven't tried something please let me know. I'm out of ideas . Thanks for your time you guys .
Hey guys sorry I haven't got back to you guys sooner . So i had just installed a new vtec solenoid w/ pressure switch. I connected it to my p72 and now I have no CEL . So that fixed one problem . I reset my ecu, brand new distributor . Wires are in the right sections . MAP and TPS sensors are connected properly . Even with no CEL I tried to get a code, my ECU is no longer throwing code21 .
My wiring looks good . I tested the wires no open circuits .
But I'm still having that same problem guys . My engine will not pass 4500rpms . Is there any other ideas that I have not tried ? Did I miss anything ?
