sputtering at idle, car runs fine.....
Old May 18, 2015 | 11:01 AM
redm3turbo's Avatar
Default sputtering at idle, car runs fine.....
So, just replaced distributor, cap rotor, plugs, wires, fuel filter etc. Car starts up great and runs great, however when idle after reaching operating temp, such as sitting at a stop light the idle will miss.
I have no idea even where to begin with this? Any ideas?
99 civic lx- d16y7 stock (almost lawn-mower)
no cel, no ecu resets
sorry fellas trying to post and do other things, you end up missing stuff
Old May 18, 2015 | 11:22 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: sputtering at idle, car runs fine.....
You begin by disclosing full car information.
There is a reason why it was put into the posting rules of this forum.
If not we assume you are working on a go cart car with a lawnmower engine.
Old May 18, 2015 | 11:32 AM
Former User's Avatar
Also, is this just a low idle issue associated with the idle relearn process after an ECU reset?
Old May 18, 2015 | 11:44 AM
redm3turbo's Avatar
no idle relearn process- have not reset the ecu in years- although it probably should be
Old May 18, 2015 | 11:48 AM
You didn't disconnect the battery?
Are you saying the engine idles to spec rpm but misfires without throwing misfire codes?
Old May 18, 2015 | 03:52 PM
redm3turbo's Avatar
No- didnt disconnect the battery ---even though I did extensive work. (Full tuneup)
So yes, Im saying it feels like it has a "lumpy" idle but just when it warms up and only at idle. During motion, the car runs perfect, no miss- no lump--nothing. Its only when Im driving and have to stop at a red light that I notice the miss.
No codes
Old May 18, 2015 | 03:55 PM
Adjust idle speed as per service manual.
Old May 18, 2015 | 03:59 PM
chrysler kid's Avatar
Also inspect engine motor mounts if the car isn't idling low below 600 rpms. Also not a bad idea to change the fuel filter
Old May 19, 2015 | 10:23 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
No worries, thought I'd bring your attention to the rules sticky just in case.
I hope you get your car dialed in. With RonJ's help I'm confident you guys will isolate it down to the proper corrective action.
Thanks for updating your first post to include pertinent car information.
Cheers and Good Luck
Old May 19, 2015 | 02:46 PM
Jimi Hondrix's Avatar
Have you cleaned the throttle body?
Is timing set correctly with strobe light?
3 Beepz
Mar 14, 2019 09:28 AM
jdm_prelude19
Apr 4, 2011 05:58 PM
easycheese
Jan 14, 2008 10:04 AM
SOHC_MShue
Sep 29, 2003 07:28 PM
