Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2010 Honda Odyssey EX-L (VCM) Vibration
Old May 18, 2015 | 09:43 AM
Tiger_Fit2007's Avatar
Default 2010 Honda Odyssey EX-L (VCM) Vibration
I cant seem to isolate a a vibration that occurs at 18-23mph and then again at 40mph. Feels like a tire out of balance, wondering now if the transmission is the source. History: the van had sat for almost 2 years with less than 750 miles put on it during that time. Van has 20K miles on it. Was previously wrecked on the drivers side (suspension only).
List of items replaced in the past 3 weeks:
1. New tires mounted and balanced
2. Front brake job, (new pads and rotors resurfaced)
3. Passenger side axle replaced (intermediate shaft/bearing inspected - no play)
4. Driver's side inner and outer tie rods (outer - dry rotted/ inner tie rod bent)
5. Driver's side lower control arm (bushings dry rotted)
6. Engine and transmission mounts (all 5...no way to spend a weekend(s))
7. Tranny drain and refill (Maxlife - Drain plug looked like a Chiapet...)
Old May 20, 2015 | 04:08 PM
soundguybob's Avatar
Default Re: 2010 Honda Odyssey EX-L (VCM) Vibration
-When getting the new tires, were the rims checked for bends?
-Did you have the tires road force balanced?
-Does the vibration occur in relation to the ECO light on the dash?
(I ask because the VCM mode will cause shakes sometimes)
Old May 22, 2015 | 11:28 AM
1. No, didn't think it would be a possibility of causing much (if any) issue with 65 series tires.
2. Next week Ill take it over to the shop to have the tires road force balanced just in case.
3. no relation to ECO mode
4. Installing drivers side CV axle tomorrow. Same side as the bent tie rod...
Old May 25, 2015 | 03:45 AM
Well the tires and wheels are fine, balanced okay. Looks like I can replicate the vibration only when the van is at normal operating temp, just prior to the 2-3 upshift...
Old May 29, 2015 | 06:41 AM
Update: drivers side axle changed, problem solved...
Old Jun 1, 2015 | 01:24 PM
xcr's Avatar
xcr
Did you do the wheel bearing when you did the CV? That would have been my guess.
Old Jun 1, 2015 | 01:41 PM
No, just the CV. Running smooth but found a cracked tranny case with replacing the axle... Looks like when it was hit in the drivers side front it was severe enough that it cracked the case at the rear trans mount and ran up along the base of the CV input housing. Anyone know where I can find a good transmission???
I thought about just buying a new case and transferring the parts w/ rebuild kit. But after seeing the amount of metal on the drain plug when I did the first A/T fluid change (6 weeks ago/1K miles ago), I'm not sure thats a good idea.
Thoughts anyone?
mateh9
Oct 22, 2014 02:20 PM
EFing8
Apr 3, 2013 07:31 PM
Saosinx
Jul 11, 2008 03:35 PM
EFing8
15
Oct 28, 2007 07:23 PM
CBL9
May 7, 2007 12:54 PM
