98 Honda Civic ex not starting
Old May 17, 2015 | 02:05 PM
Tdelgado03's Avatar
Default 98 Honda Civic ex not starting
Need everyone's help out with this one!
Its a 98 Honda Civic ex. The car is automatic. The car was driving fine. When I braked the car just turned off randomly. Car doesn't start now. It's turns over but does not start. It has no spark and not recieving fuel to the filter. We changed the distributor, fuel pump, ecu, fuel pump relay, checked the fuel pump fuse under the dash. Checked motor oil. Car is still doing the same thing. I am out of ideas and in need of help!! If anyone has ideas please let me know. I'm super confused what else it can be.
Thank you
Old May 17, 2015 | 02:11 PM
Former User's Avatar
Default Re: 98 Honda Civic ex not starting
Does the fuel pump prime in ON(II)?
Any CEL codes?
Old May 17, 2015 | 07:15 PM
Tdelgado03's Avatar
The fuel pump does prime. But it is not getting to the fuel filter. no CEL codes
Old May 17, 2015 | 07:20 PM
Bad fuel pump or crimped/blocked fuel line
Old May 17, 2015 | 08:30 PM
9sec.rs4's Avatar
When you turn the ignition 2 clicks it supply power to the starter fuel pump various other parts etc.. you could have a broken or clogged fuel line but that only answers the no fuel still then you have no spark if I had to guess I think you have a bad or broken connection somewhere in one of the engine harnesses and
Old May 18, 2015 | 05:46 AM
Tdelgado03's Avatar
I also believe there is a clog in one of the fuel lines. I am going to have a better look at it. Check under the car etc. I will check the harness to see if maybe a wire broke somewhere or something came loose.
PapaMoose
60
Oct 13, 2011 01:46 PM
4doorcivic9
Jun 11, 2008 06:31 AM
punkkid12o3
Honda Civic (2001 - 2005)
Feb 5, 2008 08:36 PM
Cameron60
Jan 16, 2007 06:04 PM
crazygerman
Mar 4, 2006 11:57 AM
