b18c lagging problem HELP!!!
Old May 17, 2015 | 01:03 PM
munrayos23's Avatar
Default b18c lagging problem HELP!!!
I need help ive tried so many things my b18c is lagging and it annoys me i did a rebuild on the head and new postin rings and all seals changed the dizzy and spark plug wires and spark plugs ive changed the ecu and it still wont go away i have no clue what it is and for some reason im getting some gas in my oil please help!!!
Old May 17, 2015 | 09:00 PM
edwinie26's Avatar
Default Re: b18c lagging problem HELP!!!
Check compression tell us the numbers also is the check engine light on?
Old May 18, 2015 | 04:42 AM
09chaplak's Avatar
Loves Tossing Salad
What are these things you've tried so far?
Old May 18, 2015 | 11:34 AM
munrayos23's Avatar
Compressions are fine my mechanic checked them for me and check engine light will come on sometimes
Old May 18, 2015 | 11:36 AM
munrayos23's Avatar
New dizzy . new spark plug wires. New spark plugs . diffent ecu . complete rebuold of the head and has new piston ring
Old May 18, 2015 | 12:32 PM
09chaplak's Avatar
Loves Tossing Salad
Did you change the distributor after the build or was that done in conjunction with? Check your mechanical timing. Can you describe the lagging? Is it at certain RPM's? All the time? Is it a bog?
Old May 18, 2015 | 01:57 PM
munrayos23's Avatar
I changed it before but its brand new and yea its a lag and it bogs out in 1st alot and wont catch speed quick and rpms drop lower then 1k sometimes
Old May 18, 2015 | 09:05 PM
edwinie26's Avatar
Check the code, if it runs fine then bogs on and off and doesn't accelerate it could be the primary O2 sensor but first check the code when it comes on. Don't just buy one and spend $60.
Still I don't see how you can get gas in your oil and have perfect compression? It has to be leaking somewhere in the head gasket or piston rings.
Let us know the Ecu code
Old May 20, 2015 | 05:59 PM
munrayos23's Avatar
Yea ill check the code once i get a chance and yea never changed the 02 sensor so maybe and yea you dont think it could be my injectors feeding to much gas ?
Old May 22, 2015 | 10:24 AM
guyver13's Avatar
check that your tps and map sensor arent switched?
KEVTI
Feb 19, 2013 01:37 AM
flaco1978
Nov 23, 2008 10:17 AM
rob_dogg55
Sep 4, 2007 08:40 PM
sickofitall1113
Jul 31, 2007 12:47 PM
TyfinHX
Apr 28, 2007 01:57 PM
