main relay pin 8 ground delay from ecu??
Old May 17, 2015 | 12:46 PM
jz2518's Avatar
Default main relay pin 8 ground delay from ecu??
I thought i fix the problem i was having with the main relay. swap it out with a new one but still same problems. when i try to start it on cold start the main relay doesnt click on. found out that that im not getting ground from pin 8 that comes from the ecu. when i jump it to ground i works. it only happens on cold starts. it takes awhile turning the key to get it to start. also it has like a 10 second delay before it clicks on.
.1995 civic with a d16y8 swap.
Old May 17, 2015 | 01:12 PM
jz2518's Avatar
Default Re: main relay pin 8 ground delay from ecu??
also i added an extra ground wire from the battery to g101 ground and cleaned the pins on the ecu. hope it helps.. wouldn't be able to tell until the car cools down.
Old May 17, 2015 | 01:16 PM
Former User's Avatar
Car information is required for all tech threads. Edit first post to include.
Old Apr 27, 2023 | 10:14 AM
greesmonkeyizzy's Avatar
did it work?
right thing to do would be get a new ecu ,
but they are harder to come by now. So I wanna know if your ground fixed the issue so I can copy you
WideBodyTypeR
May 29, 2012 04:36 PM
DDTECH
May 11, 2012 08:42 PM
hks_Racing
15
May 14, 2008 07:43 AM
white90rexsi
10
Jun 28, 2007 02:50 PM
93supercoupe
Dec 20, 2005 04:21 PM
