Cv axle question
Old May 16, 2015 | 03:30 PM
OldSchoolFool's Avatar
Default Cv axle question
Just replaced my passenger side cv axle and the inner boot looks twisted or sucked in? Is this a problem and is there a way to fix it? Thanks.
Old May 16, 2015 | 05:23 PM
GSR_BUM's Avatar
Default Re: Cv axle question
I wouldn't think so imo, but did it look that way before installing?
Old May 16, 2015 | 07:33 PM
holmesnmanny's Avatar
Typical of aftermarket axles. Over time that boot will likely tear a small hole because of the pressure of spinning. I know from experience. You can either immediately swap it out with another from wherever you bought it or wait it out. Keep in mind it gets messy when the boot winds up tearing, it will sling grease all over.
Old May 16, 2015 | 08:55 PM
No it didn't it did it right after I got it clipped into the transmission.
Old May 16, 2015 | 09:06 PM
So what actually causes this to happen? Is there really no way to fix it? I saw some post on an atv website that said the boot needed to be burped by loosening the clamp to let in some air? Never had this happen don't want to kill a brand new cv axle.. Plus Honda MTF isn't cheap and I just changed that out too.
Old May 17, 2015 | 04:04 AM
Runnerdown's Avatar
This can happen to any axle if it gets extended significantly. One of the clamps needs to be loosened to equalize the pressure inside to atmospheric. The boot will stay permanently deformed most of the time if left as is, and that does lead to premature failure.
Old May 17, 2015 | 07:16 AM
Okay well what's the best way to do this without the risk of cutting the boot open?
Old May 17, 2015 | 12:09 PM
When they tightened the clamp down the boot was pushed in.
jxhxb
Suspension & Brakes
18
May 21, 2014 06:59 AM
RanCRX
Transmission & Drivetrain
Dec 28, 2009 03:03 PM
ivan1985
Nov 2, 2006 01:10 AM
newaccordguy2003
29
Apr 30, 2004 05:35 PM
lahight
Sep 3, 2003 01:26 AM
