Squeak when pushing in or taking out clutch
Old May 11, 2015 | 02:40 PM
86azms3's Avatar
Default Squeak when pushing in or taking out clutch
There is a squeak when mid stroke in the clutch pressing or depressing the clutch. While in neutral or in gear.
After the motor cooled down I went back out to start it up and no squeak but I can hear a very slight faint whine while in neutral. It goes away when the clutch is pushed in.
Clutch replaced with an exedy oe clutch when motor was put back in.
This sound like a noisy TOB or something else?
Old May 11, 2015 | 02:47 PM
Former User's Avatar
Default Re: Squeak when pushing in or taking out clutch
Heard with engine off?
...I can hear a very slight faint whine while in neutral. It goes away when the clutch is pushed in.
You are hearing one or more transmission main bearings.
NotARaCist's Avatar
I never narc'd on nobody!
https://honda-tech.com/honda-civic-d...sting-3002401/
Not optional reading. You've been around to know better. You're missing required information.
Whine with foot off clutch = input shaft bearing. The squeak when you're pushing the clutch is either your clutch pedal needs some lubrication, or the point where the ball off the slave cylinder and fork touch each other needs cleaning and lubrication.
Old May 11, 2015 | 02:48 PM
Old May 11, 2015 | 02:50 PM
86azms3's Avatar
Sorry 96 civic dx.
No sounds when engine is off Ron.
And the squeak is like a rotating chatter squeak
Old May 11, 2015 | 02:53 PM
Old May 11, 2015 | 03:17 PM
86azms3's Avatar
Makes sense, but not what I was hoping for
Old May 11, 2015 | 04:44 PM
White_EG1's Avatar
Welcome to the shot ISB club bro you're not the only one.
pencilface
Nov 25, 2013 04:47 PM
sageuvagony
Jul 16, 2007 12:30 AM
kshymkiw83
Acura TL, RL & ZDX
Jun 17, 2004 05:59 AM
Flexer
Apr 16, 2004 07:43 AM
