oil and water mixing everywhere
Old May 10, 2015 | 10:33 AM
1320london's Avatar
Default oil and water mixing everywhere
i just bought an edelbrock intake for my b16, and im not sure of the cooloant hoses place on it so ive been trying to figure them out one by one.
im not sure wat i did but i now have water in the oil and coming thru the intake ,the motor has been not ablr too run hot or anything its never on more than a few minutes.and its causing it too smoke bad any ideas.
Old May 11, 2015 | 05:42 AM
SpeedRacerEX-R's Avatar
Default Re: oil and water mixing everywhere
The intake manifold has nothing to do with oil. Are you sure you don't have a blown headgasket?
Old May 11, 2015 | 09:58 AM
edwinie26's Avatar
^^ x2 gasket
.02...... double check your coolant hoses...find a manual
Old May 13, 2015 | 10:59 AM
1320london's Avatar
would the coolant hoses be able to put water in the motor if there hooked up in the wrong places?
Old May 14, 2015 | 06:18 AM
No. Do you know how to do a compression test?
Old May 14, 2015 | 09:19 AM
1320london's Avatar
yes but i already have the head off, just waitin for a new gasket. i might get the head shaves as well.
Old May 15, 2015 | 06:47 AM
Make sure your block is level as well... Keep in mind, that if you get either decked, your compression ratio will increase.
toeKNEEohh
Oct 27, 2012 09:44 AM
lakerschamp2000
Apr 20, 2009 10:51 AM
an2ny888
Jul 4, 2008 07:40 AM
soon2bdropped
Jun 9, 2007 02:13 PM
G2Crash
Jul 20, 2004 03:07 AM
