99-00 Civic DX Coupe - Transplanting OEM Keyless Entry
Not sure if anyone has done this before or can speak from experience but here's what I want to do:
I've transplanted power doors from a Si coupe into my DX as well as the Si floor harness, and all the matching relays, fuses etc. The power windows and locks work perfectly now.
Now I want to transplant OEM keyless entry as well, will just need to find a lock control module that goes in the driver side footwell?
Re: 99-00 Civic DX Coupe - Transplanting OEM Keyless Entry
During the previous conversion, did you install the wire harness with the 18P connector that connects to the keyless control unit? Is the keyless control unit behind the driver's kick panel already installed?
I haven't done those things, is there anything else that needs to be done besides that? I have the remote and matching lock control unit already.
