My civic 98 moonroof with very few use like once every 45 days one day it opened but did not close, I hit a couple of punches to the lining and on each punch it moved a little then another punch until it close, 1 year later without moving it, I am trying to fix it and it opened but didn't close with punches.
Any clue?
And thanks
jajajaaj thanks Ron for your help I won't hit him again, I did measure the voltages in the switch connector with the sunroof at the closed position and there is:
1- Yellow is 12v as it should be
2- yellow/red 0 volt is wrong it should have 12v
3- blue 0 volt is wrong it should have 12v
Analizing the schematic I see that my problem is the Tilt/close switch which is maybe broken or maybe dirty inside, is a heck of a job because I'll have to remove the headliner in order to get access to this tilt/close switch block, I am going to spray it with contact cleaner and see if it can get fixed because I think this switch block is not sold new.
