Hunting idle after pressing throttle
Old May 6, 2015 | 05:29 PM
JessumYessum's Avatar
Default Hunting idle after pressing throttle
I have a 1993 SI with a Y7 block, Z6 Head, and Z6 manifold. Recently I started noticing when my car is idling and I hit the gas the idle starts to jump between 1000 and 1500 RPMs. It doesent stop until I turn off the car. It also doesent do it unless I hit the throttle.
Its not a rough idle, just one that jumps up and down
Any help would be appreciated, Thanks
Old May 6, 2015 | 05:52 PM
Former User's Avatar
Default Re: Hunting idle after pressing throttle
CEL codes?
Start by clean the IACV, FITV, and throttle body.
Old May 6, 2015 | 06:03 PM
I still need to pull the codes. I'll post it/them when I do.
What should I use to clean those?
Old May 6, 2015 | 06:07 PM
Carburetor cleaner.
Remove TB, IACV, and FITV and clean on the bench. Buy a new TB gasket.
Old May 7, 2015 | 03:30 PM
I did some more testing today and had it idling for about 30 minutes. I was running through the gears and when I put it into reverse, it started to idle back and forth even faster until I put it back into neutral and released the clutch.
Also, after 20 minutes of idling, it was completely normal. It started idling at 800 RPMs. Even after hitting the gas
Would that mean its the FITV since the valve closes after the car heats up?
I also had a problem with pulling codes. I found the blue connector and put a wire in both. turned the ignition to the on position, and didn't get any blinking. it just turned off after 2 seconds, and didn't repeat.
Old May 7, 2015 | 03:36 PM
Either your wire jump did not make good contact with the connector pins or you jumped the wrong connector.
Old May 7, 2015 | 04:01 PM
Just went out and used a paper clip instead and got code 41, which is primary oxygen sensor heater.
Old May 7, 2015 | 04:04 PM
Reset ECU. If codes doesn't return, ignore.
Pashpacino
Engine Management and Tuning
Mar 13, 2018 06:23 PM
dirtyharryhatch
Dec 14, 2011 05:45 PM
carlos8
Jul 16, 2011 11:32 AM
924doorEG
16
Nov 15, 2007 06:14 AM
ATS*Mark
12
Dec 22, 2005 07:14 PM
