um ...just curious
Old Nov 4, 2002 | 11:26 AM
HatchBox's Avatar
Skoobie no more...
Default um ...just curious
does anyone sell these? and how much would they run?
thanks~
Old Nov 4, 2002 | 11:29 AM
keithv's Avatar
Default Re: um ...just curious (xxkenyon419xx)
http://www.specprod.com/ does.
http://www.specprod.com/PROD_DIR/C_P...txt&cmd2=69200
[Modified by breaka_1_9, 3:30 PM 11/4/2002]
Old Nov 4, 2002 | 12:49 PM
Charlie Moua's Avatar
Default Re: um ...just curious (breaka_1_9)
So what do you guys think of them? do they do the job?
how is the ride & handling ?
Old Nov 4, 2002 | 01:42 PM
Rob!'s Avatar
Default Re: um ...just curious (Charlie)
i hear good things about them...dont have a personal experience about em tho.
Old Nov 4, 2002 | 01:50 PM
E-AT_me's Avatar
Default Re: um ...just curious (RaceFacer)
just wondering why you would want a set.
Old Nov 4, 2002 | 02:13 PM
HatchBox's Avatar
Skoobie no more...
Default Re: um ...just curious (Rexman)
i thought they looked cool alirght...haha laugh idc...but i origionally thought they were just rear camber kits but i guess they do alot more then what i thought..oh well i will stick to washers
Old Nov 4, 2002 | 02:46 PM
Eggman's Avatar
http://thedropshop.tv/suspension.html sells them.
Old Nov 4, 2002 | 03:57 PM
bryant's Avatar
Default Re: um ...just curious (Eggman)
does anyone make some that are like 88 Si and ITR rear LCA's?
Old Nov 5, 2002 | 04:48 AM
E-AT_me's Avatar
Default Re: um ...just curious (CR-X)
see, i don't see why you'd want them.. sure, they are lighter, but then again, with those holes unless they are titanium, they may flex too much. which leads to shitty suspension.
Old Nov 5, 2002 | 05:10 AM
xtrafastcivic's Avatar
um... if you're running 15x7 rims and have negative camber you might want theses.... these will bring the rear wheels in..... But i don't see a reason to get these unless you're rubbing or you broke your current ones.... IMO
edit: 15x7 with 40 offset...
[Modified by XtraFastCRX, 6:18 AM 11/5/2002]
Old Nov 5, 2002 | 05:14 AM
Default Re: um ...just curious (XtraFastCRX)
Old Nov 5, 2002 | 08:07 AM
Red_Si's Avatar
what are these things and what do they do?
Old Nov 5, 2002 | 10:02 AM
HatchBox's Avatar
Skoobie no more...
Default Re: um ...just curious (Red_Si)
"These extreme lower control arms are for Honda Civics and Acura Integras. They are designed to allow the use of wider wheel and tire combinations and solve tire-rubbing problems."
94boostedhatch
Feb 16, 2013 04:11 AM
WillItFit
Honda Fit
22
Jan 19, 2008 05:26 PM
Tokyo_X-treme_Racer
Oct 29, 2004 03:08 PM
C-Zero
Jun 28, 2004 01:29 PM
SpiceyRice
Apr 26, 2003 07:48 AM
