EGR port plugs
I am have to clean my egr ports again cause I did clean them right the first time.I got the new type plug from Honda installed in the ports.What is the best way to remove that type plug? Do I drill it out or drill and use a slide hammer like I used with the original plugs.Also replacing the intake gaskets and rear engine mount are there any tips or anything I need to do for this to go smooth? I need a TPS gasket but the auto parts store wants to sell me a sensor and gasket.I just need the gasket.What could I do for a gasket?
Slide hammer may not work with the stamped plugs vs the original cast ones.
Usually when removing freeze plugs, I knock down/in one side to get the plug to rotate a bit and grab the opposite side with some Channel-Lock or Vise-Grip type pliers to pull it out.
Mike Lowwryyy
Mar 15, 2012 02:02 AM
gbingham
Apr 10, 2007 06:10 AM
