squeaking noise when i turn...embarassing!
Old Nov 4, 2002 | 11:01 AM
Agent Daimon's Avatar
Default squeaking noise when i turn...embarassing!
when i turn my steering wheel i hear like a loud squeaking sound outside..its really annoying and embarrassing especially in a gas station..feels like a have to spray my whole front end with wd-40..anyone know how to fix it? thanks guys..
Old Nov 4, 2002 | 11:09 AM
83Rabbit's Avatar
Default Re: squeaking noise when i turn...embarassing! (Agent Daimon)
if youve got PS its your power stearing belt.
Old Nov 4, 2002 | 11:11 AM
Default Re: squeaking noise when i turn...embarassing! (83Rabbit)
no power steering..
Old Nov 4, 2002 | 11:13 AM
One2hit's Avatar
something in the CV joint maybe?????
Old Nov 4, 2002 | 11:18 AM
Hcivic88's Avatar
Default Re: squeaking noise when i turn...embarassing! (One2hit)
sounds like something to do with steering, maybe tie rods or even the whole rack
does it only make the noise while moving, or even while still?
Old Nov 4, 2002 | 11:34 AM
Default Re: squeaking noise when i turn...embarassing! (Hcivic88)
yup..makes the noise while turning and when its still..tie rods sounds right..ill check it out..thanks
Old Nov 4, 2002 | 11:35 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
see if your ball joints have any grease left in them. if the rubber is cracked try to spray wd-40 in the crack to see if the noise goes away.
Old Nov 4, 2002 | 11:38 AM
83Rabbit's Avatar
Default Re: squeaking noise when i turn...embarassing! (fastcrxsi90)
try to use a thicker silicon based type lube as wd40 will be washed away next time it rains.
Old Nov 4, 2002 | 12:45 PM
Charlie Moua's Avatar
it's your tie rods mang. has to be!
i was thinging maybe the metal coating on the tie rods have rusted off and so the rod is rubing aginist the bolt and ....(having a brain fart,,... can't thing of the name of that thingie)
Old Nov 4, 2002 | 04:09 PM
Hondacar's Avatar
Default Re: squeaking noise when i turn...embarassing! (Charlie)
I had the same prob and it turned out to be a dry lower balljoint. Squeeled like a ****, sounded like something was ready to fly apart, but when I finally tracked it down the b.j. barely had any play in it.(unlike a sloppy bj... ) Since it was a sunday I just went and drilled a small hole in the top of it and used a needle tip grease gun on it and then ran a shortened sheetmetal screw into the hole to seal it up. Worked like a champ till i had a chance to go to the dealer and get a new one.
Old Nov 4, 2002 | 04:23 PM
Proper's Avatar
My car used to do the samething. A few weeks after it started I was pulling out of my driveway and the passenger side wheel fell off!!!!! So you better take care of it quick. Or maybe it's that Rattle Can paint job. Take care of that too Hahahaha J/K PM Me! I'll skool you on some rattle can techniques.
JDMPR
Mar 25, 2013 08:40 PM
udechukwu
May 20, 2009 01:41 AM
