Best turbo for no more than 600usd ?
Old May 1, 2015 | 08:05 AM
Prelude900's Avatar
Default Best turbo for no more than 600usd ?
I want turbo my car I limit the turbo price with 600usd. Now I can only find 2 turbo for this price 1 its Borg Warner 200sx
2 its turbonetics 54ar if I'm not wrong. I'm not looking for more than 280hp. I need the best turbo for my project but also for no more than 600usd. Any idea?
Engine is h22
Old May 1, 2015 | 09:19 AM
$amGD3's Avatar
Swaggylicious
Default Re: Best turbo for no more than 600usd ?
rebuilt gt30? precision? my pte 5431b was like 670 shipped directly from precision
Old May 1, 2015 | 10:05 AM
h22-eg-hatch's Avatar
gtx3582r clone.
http://m.ebay.com/itm/like/121329468398?lpid=82&chn=ps&ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmtid%253D1588%2526kwid%253D1%2526crlp%253D53601919689_324272%2526itemid%253D121329468398%2526targetid%253D87946136529%2526rpc%253D0.14%2526rpc_upld_id%253D48253%2526rlsatarget%253D%2526device%253Dm%2526mpre%253Dhttp%25253A%25252F%25252Fwww.ebay.com%25252Fitm%25252Flike%25252F121329468398%25253Flpid%25253D82%252526chn%25253Dps%2526adtype%253Dpla%2526gclid%253DCj0KEQjwyIyqBRD4janGs5e67IsBEiQAoF8DGj8QNCdNXUzll1EuITtetl-5zEuTb7lyQtP-3nNkik0aAuIY8P8HAQ%2526srcrot%253D711-117182-37290-0%2526rvr_id%253D823509486386&ul_ref=http%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-117182-37290-0%2F2%3Fmtid%3D1588%26kwid%3D1%26crlp%3D53601919689_324272%26itemid%3D121329468398%26targetid%3D87946136529%26rpc%3D0.14%26rpc_upld_id%3D48253%26rlsatarget%3D%26device%3Dm%26mpre%3Dhttp%253A%252F%252Fwww.ebay.com%252Fitm%252Flike%252F121329468398%253Flpid%253D82%2526chn%253Dps%26adtype%3Dpla%26gclid%3DCj0KEQjwyIyqBRD4janGs5e67IsBEiQAoF8DGj8QNCdNXUzll1EuITtetl-5zEuTb7lyQtP-3nNkik0aAuIY8P8HAQ%26srcrot%3D711-117182-37290-0%26rvr_id%3D823509486386&_mwBanner=1
Old May 1, 2015 | 10:09 AM
Stopsign32v's Avatar
Loved
I would do a Holset before a no name clone of a great turbo
Old May 1, 2015 | 10:19 AM
Prelude900's Avatar
I really want try ebay turbo but from what I know it won't last for long and also it could damage the engine maybe. It's pretty cheap most turbos there less than 250 bucks
Old May 1, 2015 | 10:22 AM
Prelude900's Avatar
How is the spool? Fast ? Slow?
Old May 1, 2015 | 02:12 PM
KevinEF7's Avatar
You should probably mention what engine this is going on
Old May 1, 2015 | 06:06 PM
TravisBiggie's Avatar
https://www.facebook.com/TurboLabAmerica?fref=ts
theyre hard to get a hold of, and the wait time is about a month right now since theyre so busy, but they can make you a replica 6262 for 550$, plus shipping. (they can pretty much make you any t04e frame turbo you want. from a 50mm up to a 62mm. They use better internal parts than precision does. I have bought two turbo's from them, both were great.
Old May 1, 2015 | 07:55 PM
doghouse's Avatar
I think the best turbo for that power is an oem Evo 8 . You can get an oem Evo turbo manifold , cut off the exhaust flange and weld on the honda flange. You will now have a true twin scroll setup. Those turbo cost like $250 used and are very reliable
Old May 2, 2015 | 05:36 AM
Prelude900's Avatar
Will check it. Thanks
Old May 2, 2015 | 05:53 AM
doghouse's Avatar
Yup, I have used that turbo in so many different application with great success. Now I'm trying one on a rotary street ported.
Old May 3, 2015 | 07:11 AM
SpeedRacerEX-R's Avatar
Cut and weld the manifold? The OE Evo manifold is stainless? Surely you're not talking about cast?
Old May 3, 2015 | 07:29 AM
TheShodan's Avatar
Moderator
You'll need two of those to get what a Honda b-series makes with one. Rotaries require much larger turbos due to their behavior of wasting exhaust energy.
Old May 3, 2015 | 08:05 AM
Prelude900's Avatar
I think it won't work very well also welding it will take a lot if work
Old May 3, 2015 | 08:18 AM
doghouse's Avatar
Well for your goal of 280whp, all you need is an ebay t04e turbo for about $135 and you can make 300whp at about 12psi.
Old May 3, 2015 | 09:57 AM
Prelude900's Avatar
I'm runing stock internals ist safe to run 12 psi ? For daily driven?
Old May 3, 2015 | 10:58 AM
doghouse's Avatar
A better question would be. How much hp the engine will hold on stock internals. That I cannot answer. I ct9 toyota turbo at 20psi flows less that a ebay t04e at 9psi. Its not about how much psi on stock internals it more about how much power will damage connecting rods.
Old May 3, 2015 | 11:00 AM
doghouse's Avatar
I am aware of that. I am testing it on a street ported motor. I will be using a gt42 with t6 1.32 ar on a semi peripheral port motor soon.
Old May 4, 2015 | 03:59 PM
planetx's Avatar
k24coupe
Aug 19, 2012 10:48 AM
1clnef9
Aug 7, 2010 05:32 AM
TurboCRXD16
Dec 20, 2004 01:22 AM
h22 civic
Apr 8, 2004 12:20 PM
94_civic_guy
Sep 7, 2003 04:15 PM
