89 integra small body repair, paint
Old Apr 30, 2015 | 03:33 PM
bheinen74's Avatar
Default 89 integra small body repair, paint
Just bought a 89 Integra at car auction last month. It has 95k one owner actual miles, and came with some rust I didn't see in the auction pics, so I have been working on it
there is no "before" on the front passenger fender. When I removed the front mudflap, the whole bottom of the fender feel off. So I cut the remaining out, this shows a complete handmade from steel patch, that was hand shaped, bent and cut, then riveted on
This show the rear lower rocker/quarter after a wire wheel, then it was treated with rust converter, small patch, bondo, sand, primer, etc.
lower passenger down to good metal, which was then rust converted sprayed, then finished up
my paint match has not got to my liking, $26 spray can ordered from bumperstore (have used that place for paint before with good luck)
another of the left side.
goal is to get better paint match and sell for a small profit, the profit goes to re-roofing my house which cannot go more than a few months more.
Old May 12, 2015 | 02:17 PM
KLeSe's Avatar
Default Re: 89 integra small body repair, paint
The paint code is located on the driver side door jamb, it should be couple letters and numbers. You can get a pint from any local paint supply. Good luck, good job on the metal fabrication.
farkiller
Aug 8, 2009 04:40 AM
MasterGDP
Paint and Body
17
Apr 21, 2007 10:53 AM
Felliph3
20
Oct 11, 2006 11:26 AM
Tommy_Gunns
Jun 10, 2002 07:06 PM
kg
Aug 2, 2001 12:26 PM
