Temp. Gauge not working!:thud: (HELP!! Radiator started leaking:scared:)
Hey so basically my ect sending unit got disconnected. The problem is i have looked at plenty of diagrams and am struggling to understand where the green wire connects to. The wire is connected to the sensor and is fed through the firewall and this is my question where do i connect it to? I found a wire that was cut connected to my fuse box but im pretty sure thats not the one because its a different color.
If you guys could help me out id really appreciate it my 94 integras temp gauge has been off since i bought it. i know i need to change my radiator and i am going to asap just really want to see what the temperature is looking like. Thanks for reading!
)Hey so basically my ect sending unit got disconnected. The problem is i have looked at plenty of diagrams and am struggling to understand where the green wire connects to. The wire is connected to the sensor and is fed through the firewall and this is my question where do i connect it to? I found a wire that was cut connected to my fuse box but im pretty sure thats not the one because its a different color.
That should go directly into the cluster. Double check the manuals: Manuals - Downloads - Hondahookup.com
All that i have been able to do with the manual is locate the temp guage wire from the back of the dashboard nd i followed it all the way back down to the fuse box. Still cant figure it out😩
So, you may need to run the wire from the sending unit back to the fusebox. Not 100%, but this should help.
Yel/Grn - Signal wire from the temp sensor to the temp gauge in the gauge cluster.
The other wire you see in diagrams is the wire that delivers 12v power to the gauges in the gauge cluster.
The wire from the ECT sensor goes through the engine bay, behind the firewall, up the dash board, and ends connected to the temp gauge by means of the gauge cluster harness. You dont connect that wire anywhere else.
If your temp gauge doesn't work, you should perform the tests posted by billabongrob to help determine why your gauge doesn't work.
dafunkdawg
Sep 25, 2002 07:32 PM
