turn signal indicator issue. need assistance please!
Old Apr 26, 2015 | 05:53 PM
zsudz922's Avatar
Default turn signal indicator issue. need assistance please!
the car is a 96 lude. well the issue is when i use my turn signals both(left and right) indicators on the dash blink at about 50% brightness. they work correctly on the exterior though. when i use the hazard switch neither indicator blinks on the dash but i hear the clicking and they work correctly on the exterior.
tried new turn signal combination switch, new hazard/turn signal relay, also a different used hazard switch. still the same though.
recent work that was done. i installed a full out security system and complete jdm auto climate control unit. also replaced all the exterior bulbs.
any help would be greatly appreciated!
Old Apr 26, 2015 | 06:14 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: turn signal indicator issue. need assistance please!
Possible ground wire or ground issue. IIRC, for a 96 the ground wires for the gauge indicator turn signal lights are from ground G402. G402 should be located on the center console, driver's side. You may be able to pull the carpet back a bit on the driver's side of the console to see the ground wires and ground bolt.
Old Apr 26, 2015 | 07:04 PM
zsudz922's Avatar
pretty sure they are good. i know the ground location your mentioning. ill double check it tomorrow though
Old Apr 27, 2015 | 02:17 PM
zsudz922's Avatar
ground is good. im not sure that is the right one though because i disconnected it and it still acted the same?
also when i turn the key on(engine on or off) for a few mins, both indicators on the dash stay on solid(full brightness) and blink correctly, besides the other staying on solid.
Old May 10, 2015 | 03:43 PM
zsudz922's Avatar
anyone have any ideas? all bulbs and sockets are good.
Old May 23, 2015 | 07:42 PM
zsudz922's Avatar
found the problem, was a bad ground. the one coming from the cluster for the indicators.
ef2_civic
22
May 17, 2013 07:42 AM
jjjellybean
12
Feb 12, 2011 02:58 AM
JasonYo
Nov 30, 2009 09:21 PM
92civicGA
Mar 2, 2007 10:22 AM
Basically
Mar 6, 2005 08:58 PM
