how many gaskets for the vtec solenoid?
Hey, i have a oil leak from around the vtec solenoid/cam plug. I changed the cam plug and still leaking a little. How many gaskets are there for the solenoid, i believe i read somewhere that there were like 3. The big one that goes against the cylinder head and there are 2 other small ones?
Two on the vtec solenoid
You may not have put enough honda bond on the new cam seal.
If the vtec gasket is leaking replace with a new one and put a small thin bead of honda bond over the new gasket and instal for a better seal.
As far as i can see there is no oil coming from the cam cap, i felt around for oil to none from there.
