Sloppy shifter in gear
What's up guys I just got my first Honda when the shifter is in gear I have a lot of side to side play. Looked the car has the innovative shifter linkage the bushings in the front look good. I was gonna order the Gpr auto rear solid bushing to any other ideas to get rid of the side to side play
Aside from internal transmission issues there are only the joints at the front, the shaft connection (bore) the stabilizer bar bushings front and rear, the bearing for the shifter, and the cup joint for the shifter ball. Check all of those areas; it's a pretty simple system. Pry / move them every which way.
DOUBLExDEUCEx22
Jul 8, 2009 02:12 PM
blackhope121
Mar 21, 2007 06:33 AM
