1996 Honda Accord Ex
Old Apr 22, 2015 | 07:21 PM
jreyes16vmz's Avatar
Icon3 1996 Honda Accord Ex
MY NAME IS JESSE I HAVE A 96 HONDA ACCORD A/C CLUCH DOSE NOT KICK IN WHEN I BI PASS IT FORM RED WIRE TO BATTARY IT WORK FINE BUT ONLY THE GLOVE BOX GET REALLY COLD BUT IT DONT COME OUT THOUGH THE VENT ALL DOORS ARE GREAT FUSES UNDER DASH AND UNDER HOOD ARE GOOD EVERY THANG IS FINE JUST I TRY EVERYTHING AND NO LUCK THE RED WIRE ON A/C COM......... NOT GETTING POWER CAN ANY ONE HELP I HAVE KIDS AND ONE ON THE WAY AND IT TO HOT ANY LEADS WILL HELP JESSEREYESWA@GMAIL.COM
Old Apr 22, 2015 | 09:59 PM
holmesnmanny's Avatar
Default Re: 1996 Honda Accord Ex
Check for continuity at the ac pressure switch. No continuity means you're low on freon which means you have a leak.
Old Apr 23, 2015 | 08:28 AM
How do I check that I know were its at but how do I check to see iffits good
Old Apr 23, 2015 | 10:19 AM
rockycat's Avatar
continuity= ohm's use a vom meter and with the wireing disconnected check the switch with your meter.
Old Apr 23, 2015 | 10:33 AM
So the switch it self the one on the line not the plug right and what do I set the meter to
Old Apr 23, 2015 | 10:34 AM
With car on or off and do I turn ac on what are the steps thanks guys
Old Apr 23, 2015 | 11:02 AM
it reads 0.0 on the switch
Old Apr 23, 2015 | 11:10 AM
rockycat's Avatar
That shows the switch is closed and under pressure.
Old Apr 23, 2015 | 11:29 AM
So is it no good cuz I tryed to use a paper clip to see if I can drump the the wire and nothing happened
Old Apr 23, 2015 | 05:27 PM
rockycat's Avatar
A paper clip will do he same thing as the switch that seems to be working so look else where.
Old Apr 23, 2015 | 07:35 PM
Also 1 last thang when I turn my car on and wait 10 to 15 mins it shuts off
Badhabits805
May 1, 2013 12:18 PM
joeldaugherty
Aug 22, 2012 10:44 PM
rhmiv
Aug 13, 2012 12:58 PM
StinkyTofu
Jun 29, 2003 01:52 PM
