Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Front Clunk - When turning over bump
Old Apr 21, 2015 | 08:33 PM
cchaok's Avatar
Icon6 Front Clunk - When turning over bump
Hi All-
I have an 05 Civic LX. About 150K miles.
Starts and runs great, but developing some sort of suspension problem.
I get a clunk while turning and going over a bump (ie a speed bump, pot hole, or even up/down a steep slant). Sometimes this produces a short sequence of clunks (2-3), but it is usually just a single clunk.
This is particularly prominent at low speeds, >15mph
I have not noticed a clunk or other seemingly suspension related noise during any other time.
I have a fair amount of car experience, but I'm not sure of a sequence to narrow this down to a particular component.
Any advice would be appreciated. Feel free to ask questions as needed. I hope that this can help others as well!
Thank you!
Old Apr 21, 2015 | 09:31 PM
toyomatt84's Avatar
Sanji
Default Re: Front Clunk - When turning over bump
Check the compliance bushings in the front lower control arms. They're a known wear-item.
Old Apr 22, 2015 | 03:42 PM
jaymez619's Avatar
I'm pretty sure it's your bushing on the lower control arm. I have the same noise and in the process of getting them fixed. I'm considering just buying the parts and having a local shop do the labor if they allow me bringing the parts. I believe the controls arms with bushings are about $50 each. I'm not sure what other parts should/need to be replaced when getting in there. Comments/suggestions are welcome.
Old Apr 24, 2015 | 06:19 AM
cchaok's Avatar
Thank you both.
Do you happen to have or know where to locate a good picture of a compliance bushing?
Thanks again!
Old Apr 24, 2015 | 03:54 PM
toyomatt84's Avatar
Sanji
Old May 11, 2015 | 03:48 AM
scr2302's Avatar
I'm in the process of changing the lower control arms with new bushings on my 2002 civic ex. Anyone know the torque specs for all suspension fasteners?
Old May 25, 2015 | 08:19 PM
2001 Manual LX's Avatar
It's kind of obvious, but the mounts for the muffler can also cause a noise that responds to bumps like the suspension might. My "doughnut" had just come loose and when I put it back, things got much quieter.
Old Jun 1, 2015 | 07:27 PM
Kyle425's Avatar
I developed a clunk sound after lowering my 2005 civic ex. I replaced the struts and springs completely and this sound came out of nowhere. Ended up changing the LCA bushings as well as the ball joints and it was still there. Sooooo after doing some digging it ended up being "coil slap" as they call it. The dead coils tend to bind up when turning at low speeds creating a "pop" or "clunk" sound. Bought Tein spring silencers made out of rubber and the problem is solved! If this doesn't work just go down the list!! : Strut bearings, LCA bushings, CV joints, axles, tie rods etc. Don't give up, you'll find out what it is.
Old Jun 8, 2015 | 09:43 PM
2001driver's Avatar
Look at the front struts same thing happened to me
Old Jun 9, 2015 | 11:21 AM
Kyle425's Avatar
Well turns out my clunk was just "coil slap" as they call it. My friend suspension was binding up creating a knocking sound. So I lurchased Tein Spring Silencers and the sound is absolutely gone. I love simple fixes.
journeyquest
Oct 27, 2008 12:43 PM
dth0ng69
Oct 26, 2008 09:17 PM
bsixteen
Suspension & Brakes
Apr 24, 2006 10:21 AM
Jordans95si
Sep 10, 2005 11:44 AM
crr
Dec 24, 2002 10:11 AM
