obd0 to obd1 distributor plug swap?
Old Apr 20, 2015 | 09:31 AM
nyckid's Avatar
Default obd0 to obd1 distributor plug swap?
was wondering will a jdm b16 obd0 dizzy work if i swap the plugs from my bad obd1 dizzy?
both has 2 plugs and the same amount of wires.
Old Apr 21, 2015 | 02:42 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: obd0 to obd1 distributor plug swap?
You can't mix OBD0 distributors with OBD1/2 ECU's and vice versa.
Old Apr 22, 2015 | 05:43 AM
nyckid's Avatar
why?
Old Apr 23, 2015 | 02:16 AM
Technical Hero
Number of teeth on the crank angle trigger wheel are different.
nyckid
Apr 23, 2015 08:52 AM
VegasInvasion
Jul 1, 2010 10:49 AM
sirtef9
Sep 13, 2009 05:33 PM
6doorsentra
Feb 11, 2007 06:57 PM
DA-MAX
May 16, 2004 01:44 PM
