Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
BRAKE Warning Light And Beeping HELP!!
Old Apr 19, 2015 | 05:04 AM
Chilly56's Avatar
Default BRAKE Warning Light And Beeping HELP!!
I consider myself quite a good experienced technician but I'm stumped on this one! My wifes 2008 Civic Hybrid has 120,000 miles all brakes/rotors and fluid flushed/changed at 95,00 miles. Brakes work wonderful fluid level is perfect but when you now drive it the brake warning light comes on along with a beep (beeps only when your moving). No other symptoms have I found. I pulled all wheels off and checked pads, shoes and no leaking. Brake fluid as I said is full, I bled all brake cylinders with no bubbles and clean Honda brake fluid.
Any suggestions what I should look at next?? I can't seem to locate an issue and I don't get a "brake system" light either just the red "Brakes" light and a beep every time I push on the pedal. PLEASE HELP as I'm trying to avoid going to the Dealerships!!
Old Apr 19, 2015 | 04:58 PM
av911's Avatar
Default Re: BRAKE Warning Light And Beeping HELP!!
Originally Posted by Chilly56
red "Brakes" light
Is that the same light when you engage the parking brake?
Old Apr 19, 2015 | 05:43 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
What you described normally will occur if the parking braking is not released all the way.
Old Apr 20, 2015 | 09:43 AM
97emsedan's Avatar
My thoughts exactly. Check and make sure your Park brake isn't still partially engaged when in the lowered position. You might need it adjusted.
Old Apr 25, 2015 | 06:12 PM
sytntyt's Avatar
Being that it is a hybrid and the light only comes on when the brake pedal is used. I've seen this a few times. It's usually related to the high pressure accumulator being defective. Small black globe looking thing mounted towards the firewall on the passenger side of the engine bay. It's filled with a high pressure Gas. These usually lose pressure and cause this issue. No codes will store. And there is no diagnostic procedure you can go through. It's basically, if you have this symptom replace this parT.
Old Nov 23, 2019 | 08:46 AM
PDHudson's Avatar
I have this same issue did you figure it out? Fluid is good and looking elsewhere now. Pads & rotors are good. Parking brace releases and drives fine....
woodenchef
Jun 23, 2014 11:59 AM
adamcm16
Apr 10, 2014 05:07 PM
ekrise
Aug 23, 2012 05:30 AM
eluded
May 27, 2006 10:35 AM
TurboTeG4
Oct 10, 2004 08:41 PM
