CA 1995 Acura Integra 4door GSR PARTING OUT CLEAN TITLE
STILL CLEAN TITLE(in hand), SMOGGED ON 3/4/15
Parting out the 1995 Integra 4 door gs-r everything available
If there is something I didnt mention, let me know
***GS-R Transmission with flywheel & clutch, GSR Virgin ECU, clutch slave cylinder & clutch master cylinder, shift linkage, pedal assembly, shift **** & shifter, Rear T bracket : $1100 & add $150 for OBD1 GSR USDM VIRGIN ECU****
If you think the price is high, make an offer.
I WOULD LIKE INTERIOR to GO AS A WHOLE, so if any tan interior guys want the entire black/gray interior conversion, hit me up, I’ll hook you up as a whole (besides the front and rear seats which are sold)
EXTERIOR
-front bumper support with styrofoam & black insert plastic caps
-rear bumper support with styrofoam caps
-94-97 oem turn signal passenger side
-98-01 oem turn signal passenger side
-Driver & Passenger Rubber weather stripping moldings & Trim pieces on the sides of chassis where the windows rest $120
-Roof Rubber Moldings (2 long strips, one on each side) SOLD
-oem turn signal housing brackets (used to mount oem 94-01 turn signals)
-OEM 4 door frost white painted side skirts $80
-OEM Frost white side mirrors $100/both
-fender liners OEM $25 each or both for $40
-Windshield Cowl $50
-windshield wiper arms with blades newer flat black paint
-integra passenger fender 94-01 original frost white $50 excellent paint, 2 dings
-integra driver fender 94-01 original frost white SOLD
-oem spoiler frost white with third brake light $75
-oem trunk frost white $100 (or $130 with spoiler)
-front passenger door, rear passenger door, rear driver door, no door panels. comes with exterior door handles and perfectly working power windows EXCELLENT CONDITION FROST
-OEM 98-01 brake lights all 4 ALL RED USDM for $200
-rear frost white door handles (no lock, good for lock delete for SECURITY purposes) $120
-moonroof glass $75
-moonroof motor $75
-moonroof glass with motor everything complete $125
-OEM antenna excellent condition $30
-all door hinges from all 4 doors
UNDER THE HOOD
-OBD1 USDM VTEC GSR/VTEC UNCUT/UNMODIFIED ENGINE HARNESS SOLD
-OBD1 GSR VIRGIN ecu $150
-OBD1 GSR OEM distributor $150
-GS-R transmission 5 speed, perfect condition $850
-AEM gsr carb legal cold air intake $150
-OBD1 OEM alternator with aem tru power lightweight pulley SOLD
-OEM exhaust manifold with a pipe & donut gasket $50 (add $20 extra for heat shield)
-OEM intake manifold $50 (no sensors, add $30 with gsr throttle body, no sensors)
-integra 94-01 gsr strut bar $40
-oem positive/negative/ground battery cables
-oem fuel filter holder with oem fuel filter (will separate)
-94-97 integra OEM brake booster with 1" inch newer brake master cylinder with reservoir
-ABS Fusebox
-Under hood fuse box
-power steering lines/hoses
INTERIOR
-Complete UNCUT/UNMODIFIED chassis Harness $300
-gsr cluster 2000XX miles $100
-5speed pedal assembly $125
-Heater/blower motor (everything under the dash for it $60
-Under dash fuse box with all fuses
-Alpine CD Deck stereo with Trunk 6cd Changer $100
-OEM Main Relay
-COMPLETE black interior (EXCEPT charcoal gray leather front & rear seats)comes with door panels (dash complete with all vents & clitmate control althought passenger airbag is deployed..i have a blank air bag dummy piece to fill it in, black steering wheel with deployed airbag, charcoal leather seats & door panels, arm rest, all black trim pieces, all gray trim pieces, all dark gray seatbelts, center console, glovebox, gray carpet, headliner & sunvisors, all door handles & switches.. EVERYTHING that was in the car EXCEPT for a stereo and deployed airbags ) 500
-black dash (no passenger airbag) $100
-gray carpet $100
-all 4 black door sills $50
-gray headliner $100 with all oh **** handles
-All gray interior pieces $50
-gray rear deck with gray speaker covers $45 ($60 with rear seat locking mechanism and key)
-Front & Rear charcoal gray seats with rear side bolters *SOLD
-front seatbelts &rear seatbelts and rear middle seat belt charcoal gray
-rear seat speaker covers $30
-front ceiling map light $25
- headliner grab handles 10each or all 3 for $25
-oem jack & tools $25
-OEM 4x100 spare never used $30
-OEM acura integra factory alarm with all wiring, alarm brain ECU, remote and installation instructions $100
-leather arm rest charcoal gray $50
-charcoal gray leather door panels (front have oem tweeters) $250
-interior black door handles all 4 with bezels with window switch/door lock switch/100
-interior driver master door lock switch/window switch $50
-climate control $50
-OEM clock on dash $20
-black steering wheel with ignition cover and turn signal/windshield washer control $60
-oem ignition with key $80
-headliner sun visors gray $20each or both for $30
-ABS ecu/ $40
-Trunk side panels $30
-Black trunk rear panel plastic $20
BRAKES & SUSPENSION & STEERING & EXHAUST
-Steering column $80
-Srteering Rack & Pinion with all tie rods $100
-gsr front rotors/calipers/brake pads (newer pads & rotors)
-94-01 gsr vtec/ls/gs/special edition cv axles 1000MILES $55 each
-strut fork $40/both
-Exhaust CHASSIS lower Heatshields All 3 for $50
-Front lower control arms complete with compliance bushings $55
-rear lower control arms $55
-OR front and rear lower control arms for $100
-greddy exhaust with b pipe $400 (add $100 for cat, passed smog 3/4/15)
if there is something i didnt mention, let me know.
(if its not listed, ask me and ill shoot u a price)
OTHER PARTS FOR SALE:::
-Acura integra 98-01 sedan 4door rear OEM brake / tail lights ALL REDS (still fits 94-97) complete full set all 4 $200
-Acura Integra 2door or 4door 94-97 only, aftermarket "smoked" or black housing front turn signal blinker lights $25
-Acura Integra 98-01 2 door OR 4 door passenger side (RIGHT) oem amber turn signal (good for replacement OR cold air duct using a dremel to still have a functional turn signal light as well)
-Acura Integra 94-01 Civic / del sol 88-2000 a/c aluminum cylinder thing (drier?)
-97/98 USDM Integra Type R/ JDM Civic Type R 15" championship white wheels with 25-30% falken ziex tires 205/50/15 with all oem type r 4 "H" center caps OR oem type r Acura "A" caps, $450 with whatever set of center caps you want, or $400 with no center caps (you pay shipping)
-3rd gen integra 94-01 2door coupe hatch black plastics (2 thin pieces that go on the sides of that big center one)
-3rd gen integra 4 door 94-01 BLACK rear trunk wall plastic
-3rd gen integra sedan 94-01 passenger front door no door panel. Has 100% working functional window regulator motor. 9/10. Excellent condition original paint from 94-97 frost white nh-538 color code.*
-3rd gen integra 94-01 rear bumper oem license plate lights (pair) with wire harness clip and bracket
-3rd gen integra 94-01 pair of radiator stays OEM with center rubber bushing
-3rd gen integra 94, 95, 96, 97 brake master cylinder excellent condition (ABS) OFF a gsr same as LS, GS, special edition models, good for eg civic or del sol, or ef crx civic with gsr brake conversion, comes with reservoir and reservoir cap and firewall rubber gasket
-3rd gen integra oem factory GSR flywheel 86k miles resurfaced @ 60k miles,
-integra/civic/ACCORD /prelude/del sol/crx/crv/other? Front license plate bolt mint plastic caps (one pair vogue silver metallic, oem genuine)
-98-02 Accord interior front driver side tan door handle & housing with lock switch
-3rd gen 94-01 integra passenger side interior black door handle
-3rd gen 94-01 integra black interior door lock switch
-3rd gen integra 94-01 driver side fender bracket
-94-01 integra non vtec b18b1 & b18a1 oem distributor cap, rotor & pcv valve
-94-01 integra VTEC b18c , b18c5 b18c, b16a , b16a2 , b16a3 , b17a1 distributor cap, rotor & pcv valve
-3rd gen integra headlight Seal "circular threaded cap to seal headlight" 94-01
-3rd gen integra 94-01 oem gray color flip down sun visor clips (hold interior headliner sunvisors in place )
-3rd gen integra 94-01 2door coupe or 4door sedan front bumper oem reinforcement beam crash bar
-3rd gen integra 94-01 oem black plastic front bumper reinforcement inserts for the sides of the front reinforcement beam
-3rd gen integra 94-01 oem a/c condenser mount
-98-02 Accord 2door or 4door green gas tank lid oem genuine
-3rd gen integra 94-01 or civic 92-95 del sol 92-97 TANABE REAR and FRONT LOWER TIE BAR RED $85ea or both for $140
-3rd gen integra 94-01 genuine jdm honda "H" moon roof visor wind deflector with all hardware also fits em1 ek eg ef bb6 tl cl tsx crv
-Honda accord / prelude / Acura Legend / TL / TL / Vigor moonroof visor wind deflector (one new Acura "A",, one used mint Honda "H" , complete with all hardware) em1 ek eg ef bb6 tl cl tsx crv
-3rd gen integra 94-01 sedan 4 door rear speaker covers gray both Left & right
-3rd gen integra 94-01, 92-95 civic 92-97 del sol hood rubber triangle piece for the under side on the left & right side
-3rd gen integra 98-01 4door sedan rear passenger tail light all red usdm
-3rd gen integra 94-01 oem genuine black dash clock
-3rd gen integra 94-01 black rear middle center belt and buckle from 4door (use it on a 2door integra with jdm seat so your child can sit in the middle for a safer piece of mind)
-oem genuine accord 94-02 & civic 89-00 japanese right hand drive automatic shifter ****
-oem JDM Honda " Torneo " gold emblem
-OEM jdm Honda "H" emblem chrome with black background came off 98-02 off japanese Honda Torneo/inspire/Prelude Sir-S
if there is something i didnt mention, let me know. pics are in my signature: integra 4 door gsr for sale thread
EXTERIOR
-moonroof glass $75
-moonroof motor $75
UNDER THE HOOD
-ABS Fusebox
INTERIOR
-OEM Main Relay
-gray carpet $100
-ABS ecu/ $40
rear disc conversion, front driver door, front and rear seats, front and rear swaybars, a/c pump and lines under the hood, p/s pump, neuspeed coilovers sold
Please see here: Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
jeremy.
Nov 14, 2013 10:50 AM
jeremy.
Nov 14, 2013 10:49 AM
Techno Tonis
Mar 21, 2012 10:45 AM
jesse95
Apr 9, 2008 09:43 PM
