b20z2 block & gsr head fuel pressure
Old Apr 15, 2015 | 10:07 AM
gregdoles's Avatar
Default b20z2 block & gsr head fuel pressure
Guys did someone know what should be the correct fuel pressure on my setup, i was running b20z2 block and gsr head with 44pcc rc injector modified ecu,right know my pressure was 28 psi.
Old Apr 15, 2015 | 11:07 AM
hondalocal's Avatar
10 Year Member
Default Re: b20z2 block & gsr head fuel pressure
If I recall correctly, my 2.0l ls-vtec with gsr head was set at 40psi when idling. I believe it went up to around 45-50 psi when throttle was engaged.
Old Apr 16, 2015 | 01:22 AM
gregdoles's Avatar
Thank u ill try to set it later
garybhoy201
Oct 12, 2006 03:41 PM
EGsLeePiN
Apr 11, 2005 07:37 PM
gSIr
Feb 14, 2005 04:52 PM
B18CRacer
Feb 17, 2003 01:01 PM
1fastEK
Feb 19, 2002 06:03 AM
